Imagine you have set up a house with hundred modules and one HC2 over the last year. About two third of your modules are clued/sticked to their place (like most of the door/window sensors that are available).
To exclude/include them to your controller they must be in direct close range to it. So you will have to remove them from their place by destroying the clue most likely.
Is there any better and easier way to reinclude these devices without buying 100m power cable and 100m network cable moving the HC2 controller from module to module?
Is it possible to use another modules with controller capabilities that is battery operated to do the ex/-include job?
Once I had to reinclude some window door sensors and I have hated it to detach them from their position and reattach them. In some cases they did not stick as well as before and tamper alarm went on or the sensor did not show the right status after a couple of days.
Alex 26
Link to post
15 answers to this question
