[email protected] 1
I'm trying to test the REST API via PHP.
GET is ok, I'm able to read and display each data in my application.
Now I want to test the POST and PUT API.
I tryed to change a device name, but nothing happens.
This is my code:
$dati = '{"id":197,"name":"zanna","roomID":6,"type":"com.fibaro.motionSensor","baseType":"com.fibaro.lifeDangerSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":195,"remoteGatewayId":0,"interfaces":["fibaroAlarm","fibaroAlarmArm","fibaroBreach","tamper","zwave","zwaveSceneActivation"],"properties":{"parameters":[{"id":1,"lastReportedValue":0,"lastSetValue":0,"size":2,"value":0},{"id":2,"lastReportedValue":0,"lastSetValue":0,"size":2,"value":0},{"id":3,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":4,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":5,"lastReportedValue":255,"lastSetValue":255,"size":1,"value":255},{"id":6,"lastReportedValue":255,"lastSetValue":255,"size":1,"value":255},{"id":7,"lastReportedValue":255,"lastSetValue":255,"size":1,"value":255},{"id":8,"lastReportedValue":255,"lastSetValue":255,"size":1,"value":255},{"id":9,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":10,"lastReportedValue":20,"lastSetValue":20,"size":1,"value":20},{"id":11,"lastReportedValue":200,"lastSetValue":200,"size":1,"value":200},{"id":12,"lastReportedValue":8,"lastSetValue":8,"size":1,"value":8},{"id":13,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},{"id":14,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0}],"zwaveCompany":"Fibargroup","zwaveInfo":"3,3,52","zwaveVersion":"2.1","pollingTimeSec":0,"alarmDelay":"0","alarmExclude":"false","alarmTimeTimestamp":"0","armConditions":"{}","armConfig":"0","armDelay":"0","armError":"{}","armTimeTimestamp":"0","armed":"false","configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"21","emailNotificationID":"0","emailNotificationType":"0","endPointId":"1","fibaroAlarm":"false","lastBreached":"1479350609","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"38","parametersTemplate":"85","productInfo":"1,15,5,1,16,2,2,1","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","sceneActivation":"0","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","tamper":"false","useTemplate":"true","userDescription":"","value":"false"},"actions":{"forceArm":0,"meetArmConditions":0,"reconfigure":0,"sceneActivationSet":0,"setArmed":1},"created":1478196735,"modified":1478196735,"sortOrder":112}';
$stringa_dati = json_encode($dati);
// Get cURL resource
$curl = curl_init();
// Set some options - we are passing in a useragent too here
curl_setopt_array($curl, array(
CURLOPT_RETURNTRANSFER => 1,
CURLOPT_CUSTOMREQUEST => 'PUT',
CURLOPT_POSTFIELDS => $stringa_dati,
CURLOPT_HTTPHEADER => array('Content-Type: application/json','Content-Length: ' . strlen($stringa_dati)),
CURLOPT_URL => $ZanGeneric->domotica_hc2_api . '/devices/197',
CURLOPT_TIMEOUT => 5,
CURLOPT_USERAGENT => 'Codular Sample cURL Request'
// Send the request & save response to $resp
$resp = curl_exec($curl);
//Trasformo la stringa in un oggetto JSON
$obj = json_decode($resp,true);
// Close request to clear up some resources
curl_close($curl);
Is there someone can send an example?
