Hello all,
Brand new RGBW module plugged into a new 24V LED strip and power supply. Module seems to be stuck on the white channel. If I turn the device off in Fibaro, the white channel stays on. I can select other colours, but its leaving the W channel on all the time.
I've tried a factory reset.
The device isn't using any switches at the moment.
Thank you,
    I did some testing.. Appears to be a short between W and GND
