Scenes are not considering the order of labels in VD
wpeeters
HCL version 4.100 (stable). I noticed that in case you change the order of labels in a VD that scene's, writing info in those labels, use the wrong one.
Reproduce it :
Create a VD with 2 labels.
Write a scene in which you write information to a label of the VD. Create 2 different scene's within each 1 of the different VD labels in it.
Test your scene's.
Re-order the labels in the VD.
Open the scenes. You'll see now it's using the wrong label.
Change to the correct label in your scene. Close the scene. Open the scene again --> if you're fast, you'll even see now that is has the old (wrong) label even still in memory. After a second, you'll see the correct label.
After the change, it's correctly working. But if you want to reorganize your VD, it can be a lot of work to change your scene's.
  • @fibaro or anybody else? Someone who can confirm this is bug or is there something else I can do?
