Main scene FTBE v 1.3.4
Hello everyone!
NEW version is OUT!
More about scene and download you can find here:
WHAT'S NEW:
  • Main scene FTBE 1.3.4 - changed function for time of day calculation and added use of SleepState global to set time of day to morning when Awake  regardless of current time
  • Main scene FTBE 1.3.0 - cleaned some bugs, added some more checks to prevent scene from stop running due to errors. Optimized and compacted code, removed unnecessary comments. DemoMode only stops changing timers while user code and scheduled events will continue to execute. Darkness can now be changed by measured lux level or global variable that is set to lux value measured by light measuring devices placed outside. Scene is now running on setTimeout function instead on sleep for better timing and also aligns to 0 seconds or exact minute.
  • Sunrise & Sunset VD v1.4.0 - Modified main loop code to better handle global variables. Variables are now automatically repaired and are not reset to default settings after HC2 reboot. Added variable SunriseIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically.
  • Home Status VD v1.1 - Added variable HomeStatIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
  • Home Timers VD v1.1 - Added variable HomeTimersIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
NOTE - This version is compatible with previous versions so need to do any changes in your current code of other scenes and VD's.
REQUEST - If you like my work and found it useful please give me support by rating and writing short review. Thank you! :-)
PS
Dear friends from Slovakia you can find this scene and VD translated to your language here:
Edited by Sankotronic
Updated to new version
  • Like 16
  • Thanks 6
    1 minute ago, necrosis said:
    @Sankotronic
    Maybe due to the new time calculation that has been adjusted couple of pages back?
    Screenshot looks good, right?
    @necrosis,
    Well, you are right, all times look good. Since I'm using completely same code as the posted one and is running for long time without problems, then there must be something in your code. I also setup same times as you on VD and still running without errors. You can send me scene code to my PM to check.
    Hi @Sankotronic,
    Is this possible?:
    set global "SleepState", "Awake", "06:45" "weekdays",  "08:00" "weekend"?
    At the moment I have declared sleepstate twice, one for weekdays and one for the weekend. Was wondering if it's possible in one go.
    To make things easier for myself I've added this to the scene:
    Because I usually add a number to much or to little and run into all kinds off errors :)
    @Sankotronic,
    Your "Main scene for time based events control" is great project. I appreciate and thank you very much for this.
    After two days of (little) frustrations I made it working. I love the clean approach you made for the timers concept.
    The delay and "frustration" was caused by first creating manually the variables and pressing "save" while in the Variables Panel of HC2.
    When I read later posts carefully I corrected it quickly.
    You well deserved good beer from my end   :)
    Guest fstae
    Hello, I have a question: In the VD "Sunrise & Sunset v1.2" I have changed  the beginning of the time night, as you can see from the second
    screenshot . The scene has adopted the change, but after one minute the scene sets the beginning of the night time to the time of the sunset (first screenshot). What is wrong?
    Hi @Sankotronic
    Quick syntax check with you
    I am looking to run a scene at time.
    If I put a time into line 282 (as below) it all works fine
    local runSceneSchedHour        = {{"06:30"},{"07:55"}};
    executing the following
    local runSceneSchedName        = {"good morning sequence","Sunrise Light"}; -- line 263
    local runSceneSchedID          = {jT.scene.goodMorning,jT.scene.SunriseLight}; -- line 265
    I want to pull it from a global variable so I added in the "own code" section (after line 416) I added
    local wakeup_time = tonumber(fibaro:getGlobalValue("WakeUp_time"))
    and then adjust the schedule hour (line 282)
    local runSceneSchedHour        = {{"wakeup_time"},{"07:55"}};
    .. but it doesn't execute
    I thought the syntax around wakeup_time should have been
    local runSceneSchedHour        = {{wakeup_time},{"07:55"}}; or
    local runSceneSchedHour        = {wakeup_time,{"07:55"}};
    but the scene won't save error free
    any idea ?
    Hi @fstae,
    Can you please check to what value is set global variable SleepState? I know it was set to Sleep and that is why TimeOfDay jumped from Day to Night. Do you have VD or scene that is taking care of global variable SleepState?
    4 hours ago, AutoFrank said:
    Hi @Sankotronic
    any idea ?
    Hi @AutoFrank,
    First you need to declare local variable under section -- LOCAL VARIABLES DEFINITIONS ---- like this:
    Then you need to add this line to function extraUserCodeFirst():
    Now you can use this variable to run scheduled action. In your case you can define like this:
    Of course wakeup_time must be formatted as "00:00".
    Guest fstae
    Hi @Sankotronic
    now TimeOfDay=night and SleepState=awake!
    The global variable SleepState is changed by a scene.
    Good afternoon @Sankotronic,
    I'm trying to make the most of your scenes and want to rewrite my alarm scenes. I use the main scene for time based events and all it's vd's.
    Do you use globals to trigger your alarm scenes? like set global disarming and a scene is triggered by that global?
    I have a rfid keypad to arm and disarm I am wondering if I can use that to set a global to run a scene that disarms the alarm.
    Thanks for your time!
    32 minutes ago, fstae said:
    Hi @Sankotronic
    @fstae,
    That just cannot be except if you wrongly mapped SleepState global variable? Check your settings again. it should be like this:
    In above example global variable SleepState has two values "Spava" for sleep and "Budan" for awake.
    @Sankotronic, I have checked your scene and goind to put it in my HC - thank you for great work!
    I`m on 4.110 and have problem in first step "Please first download "Sunrise & Sunset" VD and import to your HC. " Duing VD import I have popup with "403 Forbidded Access" error.
    Any idea what to do? :)
    Right now I`m trying using remote access.
    Edited by Bezan
    @jimicr,
    For arming and disarming alarm I use scenes that are called from another scenes so I don't use global variables to trigger them.
    Hi @Bezan,
    I am also on 4.110 and just imported one VD successfully but I'm connected locally as superuser. It is possible that you are getting "403 Forbidden Access" error because you are not logged in as superuser or because you are logged in remotely. Can you try to import VD when you are connected to HC locally?
    4 hours ago, Sankotronic said:
    Hi @AutoFrank,
    Hi @Sankotronic
    any idea ?
    Hi @Sankotronic
    I defined the variable and spent the last hour trying to debug but I cant seem to get it working
    Would you mind giving it the once over (sorry, it's prob some thing stupid :-( but I cant seem to see it.)
    If I replace the second wakeup_time on line284 with an actual time it works
    the global variable is in the format 00:00 and can be read back okay
    Do I need to declare the format some where
    I added 419 as extra code to get the global variable value
    thanks
    -f
    my code is below..
    Edited by AutoFrank
    1 hour ago, Sankotronic said:
    @jimicr,
    Okay thanks, your VD threw me off a littel :)
    Hi @AutoFrank
    You declared wakeup_time as table:
    and it should be declared as string (see my previous post):
    Also you don't need to use tostring function when reading global variable since that function always gives string, so instead of:
    it is ok to write as:
    The rest is ok. If you want to try with table then you should do like this:
    I didn't try this way with declaring local table variable but it might work. Just copy and paste, don't change what I suggested! :)
    Oh, and when you use table then you have to tell LUA to which position in table to store value thats why there are square brackets with number of position [1] in table.
    48 minutes ago, Sankotronic said:
    Hi @Bezan,
    The only account is superuser. Tomorrow will try locally.
    Guest fstae
    Hi @Sankotronic
    I have checked the variable and everything is ok. But it doesn't work, I don´t know why. Now I have changed your code, so that the variable SleepState isn´t necessary for checking the variable TimeOfDay. Now it's working!
    Thanks for your time and great scenes!!!!
    1 minute ago, fstae said:
    Hi @Sankotronic
    @fstae,
    Still something was not ok with SleepState since I use it and I don't have that problem with same scene code. But it is important that you found solution and that it is working now as expected!!
    Enjoy coding! :)
    Guest fstae
    I think so, too. In the next days I will try to find a solution for the problem!!!
