jakub.jezek 372
I have encountered very interesting behaviour in association between motion sensor (FGMS-001-ZW5 v3.2) and Fibaro switch 2 (FGS-2x3).
I set multichannel association only in Group 2 in motion sensor.
I also set parameter 12 to send ON only (value 1).
In Switch 2 settings i set there Auto off only.
1st case scenario:
Now, when i "breach" motion sensor for first time it turn Switch On as desired.
I'm trying now to encrease time to have Switch 2 turned ON by "breaching" motion sensor.
If i "breach" motion sensor second time, third time, ...., it turn off and turn on Switch 2. So relay will flash always, when i breach it.
2nd case scenario
If i "breach" motion sensor second time, third time, ...., it turn Switch 2 to oposite state. So relay turn on or off, when i breach it.
I laso made a video of that behaviours.
Does anyone has same experience with this case?
@T.Konopka Did Fibaro engeneers encountered this issue in a past?
