Problem: devices from Slave sync into unassigned instead of in the right rooms and sections on the HC2.
Tried removing and re-adding the slave, tried synchonising, tried importing, tried manual importing. Nothing seems to work. The only option I have to fix this is to manually re-assign every device from the slave to the correct rooms in the HC2.
At one point I was thinking that I should remove all the rooms and sections from the HC2 that are handled by the HCL, thinking that upon synchronising they would get imported with the devices and with correct room mapping. Removed a couple of rooms from the HC2 and re-synched. No luck. Didn't try removing entire sections. Would rather wait for the feedback of Fibaro or the community.
When working with a Master/Slave Gateway setup: should all sections and rooms of the slave gateway be manually configured in the master gateway? Or should they automatically sync from the slave to the master?
Is this problem stemming from room and section conflict issues or is there something else going on?
apgc 1
I'm experiencing synchronization issues:
Setup is as follows:
HC2: Main Gateway, 4.100
HCL: Slave Gateway, 4.100
Any help?
Thank you,
APGC
Link to post
6 answers to this question
