Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
AutoFrank
creating variables using lua or thru API
HI,
Is it possible to create a variable (specifically a predefined variable)
As part of creating a VD I want to create the variable on the fly
I looked at the developer documentation but couldn't find anything
Is this possible ?
-f
Share this post
Link to post
9 answers to this question
  • On 12/22/2016 at 9:20 PM, AutoFrank said:
    HI,
    Is this possible ?
    -f
    bumping this ...
    Share this post
    Link to post
    There are VD's that do this. @jompa68 Alarmclock does this
    8 minutes ago, AutoFrank said:
    bumping this ...
    Share this post
    Link to post
    VD:
    function globalVar(var, value)
      if fibaro:getGlobalValue(var) == nil then
        local HC2 = Net.FHttp("127.0.0.1",11111);
        local response ,status, err = HC2:POST('/api/globalVariables','{"name":"'..var..'","value":"'..value..'"}');
        if (tonumber(status) == 200 and tonumber(err)==0) then
          log("Global variable "..var.." created");
    Scene:
      local http = net.HTTPClient()
      http:request("http://127.0.0.1:11111/api/globalVariables", {
          options = {
            method = 'POST',
            headers = {},
            data = '{"name":"'..var..'","value":"'..value..'"}',
            timeout = 2000
          success = function(status)
            fibaro:debug(status.status)
            if status.status ~= 200 and status.status ~= 201 then
              print("failed");
            print(status.data);
          end,
          error = function(err)
            print('[ERROR] ' .. err)
    Share this post
    Link to post
  • 6 minutes ago, boerremk said:
    VD:
    Scene:
          options = {
            method = 'POST',
            headers = {},
            timeout = 2000
              print("failed");
            print(status.data);
          end,
    Thanks @boerremk
    Can I also use this to create a predefined variable ?
    Share this post
    Link to post
    Thanks to @petergebruers I finally learned how to make both types of global variables. Here is solution for VD and SCENE. First is to declare global variable. This is how to declare numeric variable (upper part of the variable panel):
    If you want to add predefined global variable (lover part of the variable panel) but give user ability to change values to language preferred then you do this code:
    At last if you want to make global variable with table then you declare global variable this way:
    You use this code then to check if global variable exists and if not to add it:
    Then you call above function with this code in VD main loop:
    or with this code in scene:
    Edited by Sankotronic
    Code can be used in VD and Scene
    Share this post
    Link to post
    Hello, i don't get it!
    i use this part " At last if you want to make global variable with table then you declare global variable this way: " in combination with this part " You use this code then to check if global variable exists and if not to add it: " in a scene but it dosn't work.
    i get this exeption "[DEBUG] 13:51:38: [1;31m2018-09-14 13:51:38.761675 [ fatal] Unknown exception: /opt/fibaro/scenes/189.lua:8: '}' expected (to close '{' at line 4) near 'isEnum' "
    Can somebody help me? i want to create "predefined variables" about a scene - e.g. varName=Vacation; value1=Yes; value2=No
    Cannon
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
