Start a scene when the tv is turned on with normal remote
I successfully integrated my Samsung tv. Can now control it through Fibaro. Don't really see the use of it though.
What I'd like to do is have a scene start when the tv is turned on through a normal remote. FYI: the scene will check daytime, if it's day it will close the blinds, if it's evening it will set the lights at a dimmed level, etc...
Possible?
Thank you,
apgc
" to "
Temat został przeniesiony z "
" do "
@apgc,
With HC2 everything is possible. I use VD to turn on TV and related devices. This VD sets global variable CinemaState to Yes so lights are automatically set to predefined values by Very Smart Lights scene. It also calls scene that takes care of blinds depending on time of day. I use this global variable to tell HC2 that we are watching TV because for TV and other devices control I use
. We stored and removed batteries from all our original remotes since we have complete control with Fibaro app.
Possible?
Thank you,
apgc
@apgc
I use a simple scene or vd to detect if the TV is online (its like a ping but needs an open port)
you just need the IP address of the TV and an open port (I use Fing my smart phone to scen my network and then scan for services on that TV's IP address)
vd code for pseudo 'ping', adjust as required
One anomaly is that I noticed that after the TV powers off the port can remain active for a further 20-30 seconds so the device will still show 'ON' for the scene/vd
Agreed ! You just need to be inventive I think.
I use a smart switch that the tv is plugged into and when the power increases it runs my simple tv scene .. check day or night, close blinds, dim lights .. soon to include projector and roll screen down in the man cave.
cool how there are so many ways to do the same thing !
Cheers,
al.
Hi @Sankotronic,
I am planning to order  an iTach Wi-Fi to IR this weekend.  are you still happy with yours?  also will you share your VD code or it the same VD off the Vesternet pages?
I am buying mine in order to do the following:
turn lights to predefined setting
turn on TV and wait
change  source to my Kodi player which is always on
or change source to Dune player
turn on Dune player
I have yet to decide which of the players to use
Thanks a stack
L
Hi @lennypenny,
With iTach there is no feedback from TV and other media devices of their state, but when properly setup, state of the TV and other media devices can be easily kept in one global variable table so every time when state is changed it is memorized in this global variable. This enables to use only one button to setup all media devices to what you want to watch or listen. There is additional setup VD to setup global variable according to current status of the media devices or to correct it if discrepancy occurs. I haven't finished this VD's yet but will in time.
I will gladly share my code and also help with setting it up since there will be always differences in solutions due to different media devices that we have.
Thanks  @Sankotronic,
I will place my order right now, direct from Global Cache in UK as Vesternet is out of stock
Hi @lennypenny
I could recommand the iTach Flex, if you didn't order yet.
Thanks for the input,  No I have not ordered yet.  I need to be sure which one to get.  Firstly I am reasonably sure to get a wi-fi version. Have you got the FLEX WiFi version and are you happy with the range?
My iTach will be about 5 metres away from devices to be controlled and same distance from an Wi-Fi access point.  I understand that I will have to control it with an IR Blaster
@lennypenny
I use the global cache GC-100-12 for all my av control but
With this I can control 3 TV, Projector, Sat Receiver/2xAppleTV/Android Box/BluRay Player in equipment rack ( IR blaster),
I use the LAN monitor and a networktable (global variable) to track AV states
iTach Flex is a wi-fi device. I'm using it to control my TV, Radio, Airco, Air purifier and my Room humidifier. The iTach device is on the wall in the middle of the livingroom, which is 9,5 m long. The devices i control with iTach are about 2 to 6 meters from iTach. The ir blaster comes with a 2 meter long cable, so its easy to position that device.
You can during installation easily check the IR-signal from iTach with your smartphone camera.
And ofcourse it controls also my popcorn media player and my Kodi box. :-D
iTach Flex comes with 1 IR-blaster, but you can optional buy a cable with 3 blasters connected (I almost forgot :-) )
Edited by Bodyart
Frank, if I spend that much on one of those, I will land up sleeping in my fancy garden shed.
I only just managed to get a budget of £150 for this project.  I had to wine and dine my finance minister with a good BBQ and excellent wine.
@lennypenny
point taken :-)
We've all been there and it has to be done
The trick is to get budget approval after the wine..... :-)
Hi @AutoFrank,
in case of dificulties some strong destilate coul'd be recommanded, hhh
To what extent have you automated the use of your KODI Box?
  I run KODI on an APPLE MacMini which is always on.  I have some 2,000 digitised movies running on 2 DROBO devices..  Is yours a dedicated KODI device please?
L
It's an Android "Smart TV box" loaded with Kodi app. My movies are running thru Popcorn Hour Vten from my Synology server.
@Bodyart, This I would like to hear more about if you have time, I have an android TV box and Synology NAS DS415Play and would love to have better control over my movies
Hi @AutoFrank,
that android settopbox (4K) i'm using on experimental basis yet; it came last week from China (e-bay) I'm streaming from my old Synology DS 1813+ thru Popcorn Vten (4K). So acually i have to figure out that settopbox yet. Currently i'm controlling it with it's own IR-remote. I'ts patiently waiting voor me, but i spend my time with learning lua, building scenes and VD's. So in this stage I'm not telling my system which movie to play using Athom Homey instead of sonos, because Homey can control the thing Fibaro can not, like IR, RF, Z-wave & Zigbee.
Perhaps it woul'd be usefull to ask me specific things, or i can post some report later, when it's automated.
1 minute ago, Bodyart said:
Hi @AutoFrank,
@Bodyart
Anything you could share when it's automated would be great
I'm re-building my own systems at the moment from my greenwave debacle....
Frank, I'll share everything that is tested and working, even when the code isn't clean and structured :P
