Cant get the Device ID and details of Motion sensor
Hi all,
I am new to fibaro. I was checking the fibaro motion sensor. The sensor gets connected to fibaro HC2, but its not giving the details including the device ID. SO I cant adde it in LUA, or in any room, or even cant change its name. Waiting for advices in this regards
10 answers to this question
Hi @moosairshad and welcome to Fibaro forum.
How did you include it in normal or security mode? Did you do inclusion by keeping sensor near to HC2? What notification did you get from HC in notification balloon on the top of the web GUI page during inclusion, do you remember? What firmware you have on your HC2?
From the picture I can see that is even missing X for deletion. Did you try to reset motion sensor and include it again in normal mode?
    hi @Sankotronic, I just added it normally as I added all other sensors also. I had deleted and included the motion sensor more than once, then also the same result. I will remove it and add now and give you the results
    Guest chaicka
    One thing to take note. Do not remove a device and immediately add again. Somehow, there may be backend script or activity going on that cause weird results. I have learnt to wait awhile (5 mins perhaps) before re-add a just removed device. If this still does not work, see if remove, wait awhile, reboot HC2, re-add works or not.
    I am assuming your HC2 is running relatively newer firmware version 4.1xx range since you did not mention. If it is too old version and you have the newer generation of FGMS001v2, then it may not be properly recognise since the old old HC2 firmware versions did not include support for the newer modules.
    @chaicka @Sankotronic
    My software version is 4.056.
    i REMOVED AND ADDED IT AFTER HALF AN HOUR. YET THE PARAMETERS CANT BE SEEN.
    THE NOTIFICATIONS ARE
    [09:09:19] Home Center in learning mode
    [09:09:21] Device added
    [09:09:22] Add node status protocol done
    [09:09:22] Adding devices complete
    [09:09:24] ID 61: Setting value 15 for parameter 1
    [09:09:24] ID 61: Setting value 15 for parameter 2
    [09:09:24] ID 61: Setting value 1 for parameter 3
    [09:09:24] ID 61: Setting value 2 for parameter 4
    [09:09:24] ID 61: Setting value 30 for parameter 6
    [09:09:24] ID 61: Setting value 0 for parameter 8
    [09:09:24] ID 61: Setting value 200 for parameter 9
    [09:09:24] ID 61: Setting value 0 for parameter 12
    [09:09:24] ID 61: Setting value 255 for parameter 14
    [09:09:24] ID 61: Setting value 0 for parameter 16
    [09:09:24] ID 61: Setting value 15 for parameter 18
    [09:09:24] ID 61: Setting value 20 for parameter 20
    [09:09:24] ID 61: Setting value 30 for parameter 22
    [09:09:24] ID 61: Setting value 0 for parameter 24
    [09:09:24] ID 61: Setting value 1 for parameter 25
    [09:09:24] ID 61: Setting value 0 for parameter 28
    [09:09:24] ID 61: Setting value 0 for parameter 29
    [09:09:24] ID 61: Setting value 200 for parameter 40
    [09:09:24] ID 61: Setting value 3600 for parameter 42
    [09:09:24] ID 61: Setting value 10 for parameter 60
    [09:09:24] ID 61: Setting value 900 for parameter 62
    [09:09:24] ID 61: Setting value 0 for parameter 64
    [09:09:24] ID 61: Setting value 0 for parameter 66
    [09:09:24] ID 61: Setting value 10 for parameter 80
    [09:09:24] ID 61: Setting value 50 for parameter 81
    [09:09:24] ID 61: Setting value 100 for parameter 82
    [09:09:24] ID 61: Setting value 1000 for parameter 83
    [09:09:24] ID 61: Setting value 18 for parameter 86
    [09:09:24] ID 61: Setting value 28 for parameter 87
    [09:09:24] ID 61: Setting value 1 for parameter 89
    [09:09:24] ID 61: Received parameter 1 report, value = 15
    [09:09:25] ID 61: Received parameter 2 report, value = 15
    [09:09:25] ID 61: Received parameter 3 report, value = 1
    [09:09:25] ID 61: Received parameter 4 report, value = 2
    [09:09:26] ID 61: Received parameter 6 report, value = 30
    [09:09:26] ID 61: Received parameter 8 report, value = 0
    [09:09:26] ID 61: Received parameter 9 report, value = 200
    [09:09:26] ID 61: Received parameter 12 report, value = 0
    [09:09:27] ID 61: Received parameter 14 report, value = 255
    [09:09:27] ID 61: Received parameter 16 report, value = 0
    [09:09:27] ID 61: Received parameter 18 report, value = 15
    [09:09:27] ID 61: Received parameter 20 report, value = 20
    [09:09:28] ID 61: Received parameter 22 report, value = 30
    [09:09:28] ID 61: Received parameter 24 report, value = 0
    [09:09:28] ID 61: Received parameter 25 report, value = 1
    [09:09:28] ID 61: Received parameter 28 report, value = 0
    [09:09:29] ID 61: Received parameter 29 report, value = 0
    [09:09:29] ID 61: Received parameter 40 report, value = 200
    [09:09:29] ID 61: Received parameter 42 report, value = 3600
    [09:09:30] ID 61: Received parameter 60 report, value = 10
    [09:09:30] ID 61: Received parameter 62 report, value = 900
    [09:09:30] ID 61: Received parameter 64 report, value = 0
    [09:09:30] ID 61: Received parameter 66 report, value = 0
    [09:09:31] ID 61: Received parameter 80 report, value = 10
    [09:09:31] ID 61: Received parameter 81 report, value = 50
    [09:09:31] ID 61: Received parameter 82 report, value = 100
    [09:09:31] ID 61: Received parameter 83 report, value = 1000
    [09:09:32] ID 61: Received parameter 86 report, value = 18
    [09:09:32] ID 61: Received parameter 87 report, value = 28
    [09:09:32] ID 61: Received parameter 89 report, value = 1
    [09:09:33] ID 61: Set association for group 1
    [09:09:33] ID 61: Received association report from group 1
    [09:09:34] ID 61: Received association report from group 2
    [09:09:34] ID 61: Received association report from group 3
    [09:09:34] ID 61: Received association report from group 4
    [09:09:34] ID 61: Received association report from group 5
    [09:09:43] ID 61: Device configuration finished
    Guest chaicka
    What is the version of the Fibaro Motion Sensor? FGMS001 or FGMS001v2?
    I know I may sound stupid. Have you tried these steps?
    • Clear web browser cache, close/terminate web browser, relaunch web browser and access the Home Center again?
    • Use another web browser such as older Internet Explorer (not the new Edge one in Windows 10) or FireFox (or Safari if you have a Mac)?
    • Try to access from another system?
    Some rare occasions that I get this kind of partial display screen, reload or re-click around the menus and back to the device, it will load the contents fine. Based on the event logs you shared, it definitely seems like the inclusion went fine, just nothing get displayed.
    Edited by chaicka
    Guest chaicka
    Create a scene with this script. See if the device has parameter template assign to it properly or not.
    [DEBUG] 10:32:36: Parameter Template 712 found for this device
    This is the result shown for the above scene
    Guest chaicka
    Is yours FGMS001 or FGMS001v2?
    There is a difference. One is first generation with only Z-Wave, one is second generation with Z-Wave Plus.
    FGMS-001 zw5 v3.2,   zwave plus
    @chaicka
