hi,
This tutorial is based on an idea that i believe originated to @cag014 some time back and has been adopted by many.
So well deserved kudos to @cag014 and others that helped originate and develop the concept. I am merely a scribe that has benefited from this.
I decided to write a quick tutorial for two reasons...
  1. I implemented this over christmas and and found it very useful and much easier than I thought
  2. It would appear that we have some new forum members that got HC2 devices from Santa :-)
The core of this approach is to store all the reference ID's to your devices, virtual devices, scenes, etc in a json encoded table. The references like jT.kitchen.light are used in the scene or vd and device ID can easily be changed in the table. One important benefit is that it you need to exclude/include a device the device ID will change. With this approach you simple change the reference in the Home table and your done. Without this approach you wll need to go through your code and change the device ID where appropriate.
** This doesn't get over the need to enter ID as triggers in the scene headers as fibaro doesn't allow variable in the header **
The solution has two parts to it.
  1. The home table itself where the data is stored. - this is held in a predefined variable (lower part of variables panel)
  2. The references in your scenes and virtual devices use this table
HOME TABLE
This can be created and maintained through either a scene or a virtual device. I chose a VD but there is no advantage I can thing of using one way or the other.
Go to Panel, Variables Panel and create a new predefined variable (lower part of panel) called HomeTable. When you create a predefined variable it has two values. Name the variable and save. Edit the variable and simply delete the second value.
Using either a scene or a vd create your table and store it.
This is lua from my VD. I create one button and enter the code below.
The top part shows the format of the table. I opted to place each element I am looking to store into rooms and/or other natural groupings but you can choose any way to structure. I'll attached a copy of my full table at the end of this to show what I use it for.
The next part encodes and stores the data
The last part is where I read back one entry to show the table stored okay.
the output of this when I click the button (or run the scene is as follows)
It is reading back the ID (1548) stored for Motion under the kitchen grouping
I would recommend using an external editor like Notepad++ or Zerobrane to edit/manage the code in the vd and then copy back to the vd when ready to update as the HC2 lua editor is very small
At this stage you now have your table
REFERENCING THE TABLE CONTENTS IN YOUR SCENES AND VIRTUAL DEVICES
For this you need to place the following line of code in each scene or vd
and then use references instead of device ID's in the scene code.
The easiest way to explain this is with an example. This scene switches on a light in my kitchen if it is dark, motion is detected and no light is on already
It's easy enough to see how the references are built up if you examine the scene v the table at the top of this post
and that it !!
Addition:
If you need to adjust a single parameter in the table you can use the following. This can be useful if you don't want to adjust one value and then copy the whole table back into the vd and update or more useful if you want to adjust the value in the fly in a script.
Hopefully this will help some users
If you have any suggestions as to how to improve this please let me know and I'll edit
-frank
Copy of my table to show how flexible this approach can be
Edited by AutoFrank
  • 3 weeks later...
Hi!
as far as I understood, you have to manually find your devices/Ids and enter them in the above json strukture, right? I guess for people with a lot of devices, this might be really time consuming.
Could there be a way to automatically get the device infos read-out to a json structure?
cheers
joystick
    38 minutes ago, Joystick said:
    Hi!
    cheers
    joystick
    Hi @Joystick
    There is a way to scan the HC device and create a json table
    If you take a look in the first post (
     ) and look for a reference to @ReneNL code to search the HC2. It works very well :-)
    • 1 year later...
    " to "
    Temat został przeniesiony z "
    " do "
