Alexa Skill (for not only switching lights)
Alex
Between the years I had some few seconds to learn about NodeJS, Alexa Skills and Fibaro API.
I was able to create a Skill for Alexa to communicate with Fibaro HC2 (HCL should work also).
For now it is written and configured for German language but can easily adopted to any other language.
Disadvantages so far:
The Fibaro Box must be available via internet by any port forwarded to HTTP port 80 only (unless you are creating a proxy in between). Dyndns and IPv4 are useful...
The skill cannot get certificated and set up easily.
For using it an Alexa Skill must be created manually and the code and all other options (like intents list, custom slots and utterances) must be pasted manually.
Some smaller changes in the code is needed too (abbreviations, url, port, authentication).
Also Alexa is responding only after asking for the keyword (like fibaro, house ore something like this). While using the Alexa Smart Home Skill it is not possible to have more usage than other already existing skills (like HABridge).
Advantages/Possibilities (just some examples):
- You are able to set temperature for a special period of time
- You can get and set status of global variables
- You can change up to two lights at once or all lights in one or two rooms at once
- You can call scenes
- You can get status information about open/closed doors, open/closed windows, bot at once, turned on lights
- Status information about wall plugs (turned on or off and power consumption)
- Change roller shutters status (with proper words like shut down instead of shut off).
If anybody might be interested he can ask me for the code.
I am going to publish it somewhere (maybe Github) in the next days if anybody else might get interested in this.
Also code is still not perfect. There might be a couple of bugs and it might get written better.
But it was my first time I was writing anything for Alexa and with Nodejs (don't know why I have chosen this language).
Also I would like to know some more ideas what could be done additional.
Also I am interested if anybody has some improvements (like communicating via home.fibaro.com).
11 answers to this question
  • I will post it tomorrow (hope I will find some time).
    But you can already start configuration.
    An AWS account will be needed.
    There you must create a custom skill and name it however you want.
    Next step would be to create an empty lambda function:
    Also you have to set up a dyndns account and port forwarding to your fibaro controller.
  • Feel free to edit it, use it, improve it:
    I am glad if anybody is willing to help me with this.
    " to "
    Temat został przeniesiony z "
    " do "
  • Sorry you are right, I forgot something to update ;)
    Hi Alex, i am not sure if i have configured something wrong. but when i test with AWS developer tool and call something like "Turn EntranceLight on" it appears to always be sending the turnOff command. and the json response is saying :
    your help on this would be very much appreciated.
          "name": "SwitchIntent",
          "slots": {
            "Status": {
              "name": "Status",
              "value": "turn on"
            "Device": {
              "name": "Device",
              "value": "entranceLight"
            "Yesno": {
              "name": "Yesno"
    2017-02-12T15:34:27.958Z bd600d07-f138-11e6-a07f-dd9e860771c1 Called getJsonDataFromFibaro
    2017-02-12T15:34:29.100Z bd600d07-f138-11e6-a07f-dd9e860771c1 Result: [{"id":20,"name":"Dining Light","roomID":1,"type":"com.fibaro.multilevelSwitch","baseType":"com.fibaro.binarySwitch","enabled":true,"visible":true,"isPlugin":false,"parentId":69,"remoteGatewayId":0,"viewXml":false,"configXml":false,"interfaces":["deviceGrouping","fibaroFirmwareUpdate","levelChange","light","power","zwave","zwave
    2017-02-12T15:34:29.101Z bd600d07-f138-11e6-a07f-dd9e860771c1 Sending HTTP request to: /api/callAction?deviceID=148&name=turnOff
    Edited by chrisdunn43
  • There is a small bug in the english slot file named "slot_toggles.txt".
    The "value" at "Status" should be "on" only, without the "turn".
    Can you remove all the "turn*", "switch*" and "move*" words? This should help.
    Edited by Alex
    Hi Alex, I ended up updating the Toggles with just on and off and had the same outcome. After looking at index.js and outputting to console statusValue is being returned as "on" and the if statement below on line 871 says  if (statusValue==STATE_RESPONSES.On)    when i changed this to  if (statusValue=="on") it will then work and turn on light and by default your code will set turnoff as default.
    I appreciate any assistance to see what could be causing my issue
    this is the request being sent when using statusValue==STATE_RESPONSES.On {
      "session": {
        "sessionId": "SessionId.1bd58cc7-8822-4298-b25b-dc38839e9f43",
        "application": {
          "applicationId": "amzn1.ask.skill.c25f29ad-d208-4995-bf7b-ef77c396bac6"
        "attributes": {},
        "user": {
          "userId": "amzn1.ask.account.AFVCM3UCZIBZQDP6LQQSDJNUIW73CKJE7V2YCMDUS7GO5QV4SULJKXV7AKRIIATYNLXZDE55FERRWSEV4MF5JFQC7AEDQMJO2ZSDRFGPSPR45BOHDEW6IW2NCPJ6AAGSDXS7CH5LAUKJHONKMQGPXDM2QBVLVNHSGX5J3QWIQZ7EA34AFDL4FPR7OVULTVXHNU47R2M43A2X7TA"
        "new": false
      "request": {
        "type": "IntentRequest",
        "requestId": "EdwRequestId.e7d72ceb-8838-474a-b270-795ff1dc69c8",
        "locale": "en-US",
        "timestamp": "2017-02-15T14:28:15Z",
        "intent": {
          "slots": {
            "Status": {
              "name": "Status",
              "value": "on"
            "Device": {
              "name": "Device",
            "Yesno": {
              "name": "Yesno"
      "version": "1.0"
    and the response
      "version": "1.0",
      "response": {
        "outputSpeech": {
          "type": "PlainText",
          "text": "Device switched off."
        "reprompt": {
          "outputSpeech": {
            "text": "Pleae tell me what to do or ask me a question."
        "shouldEndSession": false
      "sessionAttributes": {}
  • Thanks for showing this.
    There will be a fix in Github in a couple of minutes.
    This is just a case sensitive bug at this place, I forgot it there.
    Also I did not find this because in German language file I am using "on", the English one has it written as "On".
