Hoping someone can shed some light on this...
Trying to send a HTTPS GET request to an AWS API Gateway endpoint.
Here's the Lua code (obviously I've removed any privileged information for the purposes of posting here):
I get an 'Error:Transport endpoint is already connected' message in the debug window. That's not a response from the API (no requests get logged on the AWS side, so the HC2 isn't getting as far as making the request at all.)
If I try making a HTTPS request to another URL (like Google for example) it works with no issue. Also I know the API endpoint works, because I can call it from CURL and it does exactly what I expect. It's just from a scene.
Seems like others have had the same issue, specifically with AWS API Gateway.
Anyone know how to get this to work?
Cheers,
Dan
I've got this issue too when using Cloudflare. Disabling the CDN works fine.
