Fibaro ID with tablet app
Orgli
How can I use the new Fibaro-ID with my Android tablet Fibaro app ?
App tries to connect only to home.fibaro.com ?!
11 answers to this question
  • Yes...as we all thought...regarding to Fibaro, there will be a new version of the Android tablet app, soon.
  • Yeah! Finally the new Android app (tablet) was released and it works as it should. Thanks to Fibaro!
    Suggestion: Please, relase new functionalities / new versions for all platforms (iOS, Android...) at the same time.
    yep, it works for me....login possible....
    Only for (Android) HP Slate 21, its not possible to download from Google Store (not compatible)
    solution;
    - remove old App (from settings -> Apps)
    - download apk file
    - install manual the apk file
    - Skip Fibaro ID
    - log with local account
    - done
    Edited by twanve
    Please try to change weather provider (in Configuration) in Home Center's interface and refresh data in the app.
    If you didn't install other weather provider yet, please go to Plugins and install it. After this you will be able to change it in Configuration.
    i try to change, but i have the same problem
    " to "
    Temat został przeniesiony z "
    " do "
