I have 2 light switches on top of each other:
- One is part of a two way switch
- The other one is a "normal" switch
In
 (sorry I've found only a german link) it says I have to define Paramter 13 to 0 to use the switch as a two way switch. The description is for FGS-212, which seems to be a single switch.
FGS-222/FGS-223 have two switches (as said I have 2 light switches) - Is it somehow possible to use one switch as two way switch and the other as "normal" switch. Or do I need two FGS-212, one for each of the two switches?
Thanks!
    Just a short note - Parameters including 13 is explained here:
    0 – turn on/off the device on switch status change
    But it doesn't say if this is a global setting for both switches or can be set individually.
