Guest MarcelK
Hi Forum users,
I just did the upgrade of my HC2 and also did create a Fibaro ID account (migrate the old one)
But i have a guestion...
Is it now possible to create a Fibaro ID account for each individual local user that what to use the system remotely... or is that still a "shared" ID for the remote portal? (and so all the new sevices in the future?)
@Fibaro: you may comment also... thanx.
Regards, Marcel
you can do it - look it closer in configuration and then access control. When u add new user then you can edit it that user and then change rigts and even change email for that user
Still shared I wished also it was fully cloud based with everyone a different Fibaro ID in that case FibaroID actually made some sense, Right now it is the same as it was, only user name became => email address.
Guest MarcelK
    @confesor: That is not really what i ment. As @parsariaalso stated... it is stll a shared account. I haven't tried it yet but if it is not a shared account then it should be possible to assign "one" HC2 controller to different Fibaro ID's ... and ... i think that this is not possible... i hope @fibaro will step in and tell us.
    Guest MarcelK
    I think you are right.
