3 hours ago, jgab said:
Table.group.option4=1000
Thanks @jgab that was embarrassingly easy! I'd been messing about with table.insert for ages. Thanks this is going to make that first QA better!
I've also been trying to insert a new line in this nested table
Table={
al_1 = {cw=1, ww=10},
rgbw_1 = {r=38, g=13, b=1, w= 1},
sl_1={sl=10},}
To make it like this....
Table={
sl_1={sl=10},
newLine={new=*1},}
I'm pretty sure I need to use table.insert but I can't figure out the syntax. Again its probably something simple but I can't figure it out!
god Jul
Table={
sl_1={sl=10},}
Table={
sl_1={sl=10},
newLine={new=*1},}
god Jul
Lua tables can be either arrays (with consecutive values) ex
or of type key/value
table.insert (t, pos, value) is only used when inserting a value in a Lua array. It inserts a value at a specific position moving all values, at that position and above, one position up.
Ex.
will create
It's very common to use table.insert to add a value at the beginning of an array and move all other values a step up.
To add an element at the end of and array you can use
If you have a table table with key/values, like in your example, table.insert does not work/apply.
Hi @jgab Many thanks for the solution and the explanation, this really helped me.
My first QA sliders to set CCT light brightness and ambience is now working :)
tack för din hjälp och ditt stöd
@irekk this might be helpful to you as well
  • 1 month later...
can you also remove a id or number from a table
example.
if a door is open table.insert(doors,doorId) gives me table like [209]
this wil ad another door if this also open gives me table like [209,288] etc
but when the door is closed it has to be remove from the table.
How?
thx again
Found it
if fibaro.getRoomID(door)==rID then
   for k,v in ipairs(doorTable)do
    table.remove(doorTable,k)
Edited by Kage
It will remove all items in doorTable....?
In general, it can be good to extend the table functions with some "missing" functions
I hope Not!😁
No whem the roomID(door) is identical to roomID it wil remove from the table where k stands for the number in the table eq position to be remove.
i trying to understand you. if i'm correct this part looks for some data in table if not it returns obj eq table or........
this part looks if it is a both the same and than if one of them is a table. if equal en not table then false. if one or both are table then if pos 1 of e2 is not nil or not equal to .......and then you lost me..........(v1,e2[k1])......
v1 is always diffrend then k1 or e2[k1] where k=key and v=value!?
10 hours ago, Kage said:
I hope Not!😁
Nope, this code
will remove all items in doorTable as it loops through all items with pairs and removes them, one by one... You should have the test inside the loop if you only want to remove one.
The functions are what they are named.
The first copy any Lua table. The second checks if two Lua objects are the same, including Lua tables.
I think the equal function is the most efficient one can do in Lua - someone that has a better one?
1 hour ago, jgab said:
there is a missing part, this only yes it removes all. it also has to check if door is open
more like this
idR={234,456}
doorId=api.get("/devices?baseType=com.fibaro.doorWindowSensor&visible=true")
function doorValue(id)
    for i=1, #id do
        idD=tonumber(id[i])
        if _f.getValue(idD,'value') then return true end
    return false
function deviceIdFilter(id)
    for _,i in ipairs(idR)do
        if id.roomID==tonumber(i)then return true end
    return false
for i=1,#idR do
    rID=tonumber(idR[i])
    if deviceIdFilter(doorId) then
        if not doorValue(doorId) and light and next(doorTable)~=0 then
                if v==rID then table.remove(doorTable,k)end
i know if there are more then one door in the same room it will deleted both. i think 🙄 all my rooms have one door one window one ceiling
i will differently try your codes if only i am a amateur :)
Edited by Kage
