Hi @AutoFrank, sorry to bother you..
I remember reading something on the forum about how to create a json table straight from the main loop of a VD when you press save the first time.
But I can't find it. Do you have a clue how to?
Thanks,
Jim
Thanks,
Jim
Hi
Now.. The question was obviously not directed to me, but...
I do that on several places in my DSC alarm to HC2 integration code. I also extend, modify and delete json tables in the main loop. You can look at my code here and maybe get some inspiration...
Just ask if you have some questions...
Regards
Peo
Just now, pos said:
Hi
Regards
Peo
Thanks, will look at it this weekend!
Jim
    Thanks,
    Jim
    Hi @jimicr
     No bother....
    Could you expand a little ?
    Are you looking to create a table, json encode it and store it in a newly created global variable or an existing valiable or just create a table to be used local to the main loop?
    _f
    Hi @AutoFrank & @pos,
    I actually found where I read about it, it was in the beta test for @Sankotronic weather VD.
    I pieced this together from the post of @petergebruers:
    Mainloop of a VD:
    To test:
    And to change the values:
    The thing I noticed is that as long as the code is in the main loop you can't delete the created Global from the panel.
    Thanks all for your help!
    Jim
    Mainloop of a VD:
    To test:
    Jim
    Glad you got it sorted @jimicr
    Looks like I cheered to soon,
    I have to do some more tests, creating or trying to delete the Global presses the save button and destroys all the vars...
    Okay, found out what messed with the Globals: If the creation code exists in the mainloop of a vd and you try to delete it destroys the Globals
    Edited by jimicr
    Hi @jimicr
    Is you press save on the global variable page the value stored get corrupt
    Try and avoid this if you can.
    The code to create a global generally had a check to see if it exists before trying to create so if you run it in a main loop then it should only try and create once.
    When I am developing code that will run in main loop I first develop it in a button so I can control when it get executed.. might be an approach worth considering for what you're working on ....
    6 minutes ago, AutoFrank said:
    Hi @jimicr
    I didn't press the save button, that's the weird part.
    I had it all working and try to remove the testTable var I created and then all went into a downward spiral :)
    @jimicr
    That doesn't make sense...
    Did you get it back working ?
    1 hour ago, AutoFrank said:
    @jimicr
    First (I think) the lua engine crashed all scenes where throwing an error something like :line 35 :T don't remember. Then I noticed that all globals that can be affected turned to the NaN.
    Rebooted removed my test vd removed the created global restored all the globals and am back.
    Will raise this as an issue later.
    Thanks for asking
    • 1 year later...
    " to "
    Temat został przeniesiony z "
    " do "
    • 2 months later...
    Hi all,
    I have a request which I expect that can be solved/simplified using JSON and global variables.
    What am I looking for;
    When I arm my alarm I would like to store the value of several lights in house.
    After values are stored ( in the enable alarm scene) , I would like to automatically switch all lights off .
    When the alarm is armed and breached, I want all lights to be set to 100%.
    When the alarm is disarmed I want to restore the lights to the value at the moment the alarm was enabled.
    How can I do this without the need for each light to have its own global variable? (I guess JSON table could help).
    I'm not a code expert so help is needed.
    Thanks in advance for help!
    Jules
    Hi
    You could read all values and write it to a single global var. But that is probably not optimal. You could also write ids and values as pairs in a single predefined variable. Probably better, but still not optimal. I guess JSON in a global variable is not wrong here...
    Just some thoughts...
    I do the opposite to what you do. When I arm my alarm and leave, an "away lights" scene starts. That have both fixed times and times related to sunrise and sunset. I automate lights in the house when away to make potential burglars believe someone is at home. If it is dark, a burglar knows for sure you are away. When I get home and disarm, the scene stops. The scene however leaves the lights in the current state they had at disarm time. Thats me :)
    Peo
    • 1 year later...
    i was trying to go through this turorial. Especially the saving and reading of tables to global variables interests me.
    So i copyed the code into a scene. My code looks like this:
    when i run this scene as described in the turorial i get the following error:
    [ fatal] Unknown exception: /usr/share/lua/5.2/json/encode.lua:93: Failed to encode value, encoders for function deny encoding
    apparently the initial variable is called "Table" instead of "table". After correcting this error, my code looks like this:
     running the scene now results in:
    [ fatal] Unknown exception: /usr/share/lua/5.2/json/decode.lua:74: bad argument #1 to 'match' (string expected, got nil)
    I was also wondering why setGlobal refers to "StateTable" whereas getGlobal refers to "Table".
    Has anyone any idea why this isn`t working as described in the tutorial?
    In your browser go to Panels, Variables Panels and create "StateTable". It isn't created automatically for you. I have tested your scene, after creating that global variable, your last scene prints "1560" as expected.
    i indeed didn`t know that i have to create the global variable in the variables panel beforehand.
    maybe the creator of this post could fix the 2 issues with the tutorial`s code.
    Also Thanks to the author of this post for the great tutorial.
    much appreciated!
    • 8 months later...
    Hello , i read inthe forum up and down, but i can't find a solution for my proplem. I make an http request on a virtual device and become this output:
    -- Setze Verbindungsdaten
    -- hole ip adresse aus virtuellem modul
    local selfId = fibaro:getSelfId()
    local IP = fibaro:get(selfId, "IPAddress")
    local Port = fibaro:get(selfId, "TCPPort")
    local versuche = 3
    -- setze variable MOWER aus IP und Logindaten
    DG = Net.FHttp(IP)
    --check Onlinestatus
    local function _ping(retry)
            fibaro:sleep(500)
        retry = retry or 0
        local tcpSocket = Net.FTcpSocket(IP, Port)
        tcpSocket:setReadTimeout(250)
        --fibaro:debug('Suche..., versuche #' .. retry .. ' bitte warten...')
        fibaro:sleep(250)
        local bytes, errorCode = tcpSocket:write('ping')
        if errorCode == 0 then
            return true
        else
            if retry < versuche then
            --fibaro:debug('Nicht gefunden, erneut versuchen, bitte warten...')
            fibaro:sleep(500);
        return _ping(retry + 1)
        return false
    local f, result = pcall(_ping)
    if (f) then
        if (result == true)
        then
        --xy
     else
            fibaro:sleep(300000)
    else
        fibaro:debug('Error: ' .. f)
    -- geting info about specific device
      response = DG:GET("/info.jsn")
     fibaro:debug(response)
    -- decoding json string to table
     extractedjson = json.encode(response)
    fibaro:debug(extractedjson)
    output:
    /monthly_2020_08/grafik.png.b71a3d0eaf5f2cfa2cdf15db192e1b20.png" />
    I think there is an easy solution to separate specific value and transfer it to a global variable. But i can't find it. I try with several variants of table or string entrys - no result. Have anybody a solution statement?
    Thanks in advance.
    • 2 years later...
    Hi @AutoFrank
    Thanks for the great tutorial on tables. I often use tables in the format…
    Table = {
        group = {
            option1=1560,option2=1507,option3=881
    Reading values, assigning new values, encoding and decoding works great. Now I want to be able to add eg “option4=1000” so the table becomes…
    Table = {
        group = {
            option1=1560,option2=1507,option3=881,option4=1000
    I can’t figure out the right Syntax / way to do this. If I can figure this out it will make my lighting scene code a lot simpler
    8 hours ago, Rosavision said:
    Hi @AutoFrank
    Table = {
        group = {
    Table = {
        group = {
    Table.group.option4=1000
