[TUTORIAL] Introduction to Lua tables (2nd edition)
AutoFrank
**MAJOR UPDATE TO THIS TUTORIAL**
This tutorial has been going through a major update and expansion since the first release. Special thanks deserved to @petergebruers and others for helping me understand many of the underlying table concepts and for also contributing a lot to this tutorial. It may be a good idea to paste some of the code in this tutorial into a test scene to understand how they work by reviewing the output
Topics covered with lots of sample code and expected outputs
  • Table basics
  • Creating tables and printing  (ordered,  non-ordered, numerical and non numerical keys)
  • #operator - pros and cons
  • kv pairs  - advantages
  • Updating tables - adding adding, inserting values
  • Nested Tables - printing, updating, inserting,
  • Summary of key points
  • Storing tables in global variables
I would have found this very useful when I started so hopefully some users will find it useful as well.
-frank & peter
Tables
A table is a tree structure, consisting of field and each field has a "key" and "value" pair.
The key can be any Lua value except nil and NaN. A table can store anything except nil.
The name of the table is the variable that stores a reference to the table so it can be accessed
Creating Tables and displaying the table data
a = {}
This is the smallest table and stores the reference to the table {} in the variable a
Consider the following table
fav is the table (or at least the name of the variable where the table is stored),
in the above table 'fav', it has 5 fields and each field consists of a key/value pair
4 is the key and 4FM is the value , 2 is a key and 96FM is the value, etc
You can display all the key/value pairs using the following ...
the result is ...
/monthly_2017_02/result.PNG.78c043a440f8a84918431f4197f1a1fb.PNG" />
and you'll notice that the results are NOT returned in order
if you have numerical keys [1], [2] then you will need to use ipairs to return them in order
#operator
The #operator (#tablename) is used by a lot of people to identify the length of the table and use this to iterate through the table but it is not always recommended
an example of where it will work is here
if the table keys are numerical and contiguous, it will work..
....but if they are not or you have inserted or removed values then it won't work
A good example of where it doesn't work very well is here
you can see that the second loop in the debug is showing an #operator value of 5 (because it is the last key but there are only 4 key/value pairs as we removed one
Another approach that is recommended to use is as follows
use the k/v approach to count the fields and then use the counter to iterate through..
and you can see that the counter is correct in both loops
Updating Tables
you can update a table by setting Key/Value pairs  or delete a value as follows
if the k/v pair already exists it overwrites it or of the k/v pair didn't exist, it simply adds it as above
This is the same example but the table has the numerical keys explicitly defined
Example of adding key/value pairs to this table using table.insert
The extra key/value pairs will be added as extra fields as you cannot specify the exact field you want to update as in the approach above
Tables with non-numerical keys are also possible as shown below
the same table can be represented in a simpler form
If you chose or have to use non numerical keys or a mix, then Lua makes no guarantee on order as the spec says random.
The only way to order a table with non-numerical keys (such as alphabetical order) is to use an external reference.
Nested Tables
Lets take the following table, it looks like each value in the key/value pair is a table in itself as if one table is nested inside the other
if you run the usual k/v code you will see the second/nested set of tables
To list the k/v inside the second table you need to iterate through the first table
we use a counter like before to find out how many fields are in the outer most table
There are two tables nested within the outer most table
  • table [1] which has two fields with k/v pairs
  • table [2] which has two fields with k/v pairs
we then use the counter to expose the k/v pairs at table[1] and table [2] with the following result
You could also expose specific values (in the nested able) using the following
with the following expected result
You could also have used the #operator that we discussed earlier BUT only because the key's in the outer-most table are numerical and contingous
Updating a value in a nested table
If you want to update a specific value in the nested table you need to use the k/v method we have discussed
the result is
If you want to add/insert a new k/v pair in the nested level, you can use the table.insert method
and the result is three fields in the table
So before we go to the last task of storing the table in a global variable, I thought it would be good to have a quick recap..
Summary
you can explicitly declare a numerical key in a table but you don't have to
  • for a table with a numerical key - use ipairs to print the table fields in order
  • #operator can be used but ONLY for tables with numerical keys that are contiguous
  • it is recommended to use the standard k/v approach to count the number of fields
  • remove a value by setting its key = nil
  • update a table using the table[key] method
  • add a new field using table.insert(table, "value") and will add a numerical key
  • table.insert will not work with tables with non-numerical keys
  • tables with non-numerical keys cannot be printed in order by ipairs, result will be random
  • nested tables require iteration to print the inner-most tables
  • multiple levels of iteration required for multi-nested tables
  • updating nested table - iterate with k/v and use table[key].nested-key = "value"
  • inserting into nested table - iterate with k/v and use table.insert(table,{key="value, key="value}
  • tables can be very confusing and frustrating to us newbie's , so take your time :-)
Storing a table in a global variable
if you take the following table structure
If you want to store this table in a global variable you will need to encode the table as a string. One of the most common formats to encode a table (structure) is json
from json.org
"JSON (JavaScript Object Notation) is a lightweight data-interchange format. It is easy for humans to read and write. It is easy for machines to parse and generate."
To save the table you need to encode it  and then save it to the global variable
In order to read back a single value you need to decode the string
once it's decoded you can then read one of the values or manipulate the table
Updating a single value
- assign the new value, encode it and the store it.....
Making json strings/output easier to read...
Sometimes a json string can be difficult to read and understand its structure. Typically they would look something like this...
There are a number of websites that will 'pretify' the string make it easier to read the structure and enable you to understand how you might navigate it.
If you take json string above and paste it into
 it will display it more like a table
This format is easier to understand
Finally....
There is a very good discussion on using a table in a predefined variables to store the ID's of scenes and devices for the HC2
suggestions to improve welcome
-f
Edited by AutoFrank
  • Like 7
I put this in one of my scenes:
lamp_ON = {"79", "148", "153", "238", "239", "284", "298", "299", "312", "313", "314", "314", "322"}
    --print("#operator: "..#lamp_ON)
    for i = 1, #lamp_ON do
        if  tonumber(fibaro:getValue(lamp_ON, "value")) > 0 then
              fibaro:debug("Forgotten to Turn this Lamp OFF: " ..lamp_ON);
Output in debug if light is ON:
Forgotten to Turn this Lamp OFF: 79 < Lamp ID
But instead of the Lamp ID I would like to have a text.. like:
Forgotten to Turn this Lamp OFF: Kitchen Table
How to accomplish this?
@samuel, the following should work:
fibaro:debug("Forgotten to Turn this Lamp OFF: " ..fibaro:get(lamp_ON, 'name'));
Best, Rene.
i get this error:
[DEBUG] 14:41:48: line 115: attempt to concatenate local 'deviceId' (a table value)
-- table with Lamp ID's
        if  tonumber(fibaro:getValue(lamp_ON, "value")) == 0 then -- > 0
              --fibaro:debug("Forgotten to Turn this Lamp OFF: " ..lamp_ON);
  • 9 minutes ago, samuel said:
    i get this error:
    Hi @samuel
    As far as I can see you may need to use a call to the HC2 api using the device id to determine the device name
    I don't have time this minute to do a full solution but here is the api if it helps
    you'll need to pass the 'id' to the http:request string
    'result' is the http response table that has the name you need.
    2 hours ago, AutoFrank said:
    Hi @samuel
    The API is certainly a generic solution, but HC has a builtin function to determine the name of a device. Like this (plus some other corrections to the code):
    Edit: fix type of table values and add nil test.
    Edited by petergebruers
    thanks @petergebruers - more like what @ReneNL was referring to .... :-)
    i got an error: [DEBUG] 15:48:54: line 36: Assertion failed: Expected number
     Line 36 below:
    in pairs,
    I tried the one from @ Autofrank with ..id.. ..(79).. for a try, then i got the whole json string as output...
    Edited by samuel
    the table input are the id's from the lights
  • **MAJOR UPDATE TO THIS TUTORIAL**
    This tutorial has been going through a major overhaul and expansion since the first release. Special thanks deserved to @petergebruers and others for helping me understand many of the underlying table concepts and for also contributing a lot to this tutorial. It may be a good idea to paste some of the code in this tutorial into a test scene to understand how they work by reviewing the output
    • Table basics
    -frank & peter
    Edited by AutoFrank
     Line 36 below:
    in pairs,
    @samuel
    slight tweak - turning v into a number
    Try this
    1 hour ago, AutoFrank said:
    @samuel
    Try this
    Thanks. Yes... I didn't catch that because I tested the code on my HC2, and purely, out of habit, I defined the lua table like this:
    You see the important difference? No quotes! So my values were all of type "number", while the original question defined them as strings! It's syntactic sugar, again!
    I also fixed another issue, in case you use a wrong ID and your device doesn't exist:
    This is very idiomatic Lua:
    (fibaro:getName(v) or "")
    and it means: get the name, or alternatively use an empty string if the name was nil. This is needed because the concatenation operator refuses to add nil to a string and aborts the script...
  • 6 minutes ago, samuel said:
    Thanks guys: did did the trick:
    @samuel
    Great news
    if you use the rest of @petergebruers code it'll give you a bit more resilience
    How to compare a value from a table, so that an action can be performed?
    table = {
      [1] = "dim",
      [2] = "bright",
      [3] = "off",
    if value from number [1] == "dim" then
    -- code
    thanks for your help
    Here's an educational example. Does this help?
