  • 3
Qubino smart meter
I just buy a qubino smart meter, and seems to work fine in HC2 web interface but in mobile interface we can't see correct, any help?
I've contact Qubino and they say is Fibaro fault.
Fibaro just displays values. I do not have any experience with Qubino, but how it is set? Meaning how big is accuracy, according parameter settings?
    Accuracy is ok, i test same module on a device that has in past a fibaro module, and report same value in W. About parameters you have to set mannualy, fibaro unit show this device without templates. I send email to fibaro but seems they newer answer to our problems.
    The real problem is mobile app display, this is the reason we buy this module to show real time consumption on a set of devices, since fibaro app not show this....i plan to refund.
    Remember to tick off new devices for the user to show it in the mobile app. I had the same issue with virtual devices added after I had made the user first time
    Good evening, I'm sorry for my English :( I have equipment Qubic 3ph smart meter, you do not have somebody please type as the settings manually adjust?
    ADMIN'S NOTE:
    Edited by T.Konopka
    https://forum.fibaro.com/topic/30009-how-to-properly-attach-images-and-clips-to-your-posts/
    I have the same problem too. From mobile app I do not receive any value on consumption.
    Reading here on the forum it seems that up to firmware 4.134 of fibaro worked.
    We have to make a ticket to fibaro.
    Same here, tested the3 phase  Qubino Smart Meter with HC2 on version 4.180 with no luck. It is added to the system byt there are no reports.
    The smart meter works in Zipato system without any issues but Fibaro wont report the values. Could you report this @T.Konopka ? Thanks
    Which device do you guys discuss?
    OR
    Did it work before? Was there a template for the device?
    I do not know:(
    Guest kallecux
    Any News about the problem - i have the problem to.
    Thanks.
    @T.Konopka any news about the Problem with the 3 Phase Smart Meter not usable  with Fubaro?
    I‘m also getting no values from my Smart Meter.
    I Hope my prediction of not getting any answer here won’t be right
    @StefanS , there is no news about. The fix has not been released for this.
    If you want a direct reply then you should contact our Support at [email protected]
    I have the same issue as OP, my Qubino Smart Meter only shows watt use in the web interface, and not in the mobile Android app.
    I have Fibaro Home Center 2 v. 4.510
    Edited by darkultra
    Guys, today I bough 3 phase qubino smart meter. On weekend I have a plan mount it to DIN and after I can build simple VD for monitoring all parameters in mobile app as workaround ... if It will be ok for yours.
    ok?
    Edited by 10der
    ok?
    You will not get it to work. I tryed several times with no luck. You will not get any Reports Ort values.
    So I had to included it directly to my ioBroker by USB Zwave Adapter.
    stop. a device doesn't pass any data to Fibaro HC2 or we can't see some data in mobile app?
    @StefanS
    It does not pass any data and get the Status unconfigured in HC2.
    same Problem Homesystem.sk postet above.
    can not get it to work under 4.180.
    if you have 4.510 you can try and give us an Update
    Edited by StefanS
    crazy
    yes I have
    4.510
    @10der I‘m very excited about your Weekend Test result with your Qubino and 4.510.
    and your VD will also be welcome..
    Edited by StefanS
    I will be keeping you and others in the loop.
    Is there any news regarding testing with the Qubino Smart Meter?
