I am looking for help in decode a http success message
If I issue the following through a browser it works....
and the response in the browser is
now, if I run this in a scene
It also works but I cannot find way to display the success message ( I want to trigger another action if not successful)
I tried removing the " ==200 " if-then loop as I can't see any 200 or 201 result.
Could somebody explain what the
is doing and I may be able to figure out why I may not be seeing the success message
-f
15 answers to this question
    okay, I have verified the format of http GET request is correct
    If I run a request against the HC1 api and use a print table/nested table function from @petergebruers I can see the kv pairs
    scene code as follows...
    If I replace the url with the call to the sonos-http-api
    the http GET request completes successfully (as I can hear the sonos player saying hello)
    .. but I get an ERROR - Operation canceled in the debug window
    /monthly_2017_02/Capture12.PNG.06d5c6f12537e95e5c47b159aecce7a5.PNG" alt="Capture12.PNG" />
    I also can't decode the http response.
    In wireshark I can't see the 200 code, but if I drop into a browser I get a success message back in the browser window as shown above.
    Any ideas or suggestions welcome
    -f
    Long shot... does the second command take longer than 2 seconds? Now in the request you have "timeout = 2000" (ms). I'd try 10000 or so.
    thanks @petergebruers
    in a browser the 'success response' is pretty quick
    I'll tried 10 and 20 seconds and no luck
    I'll try and find out more about the http response from the api developer
    a little more info
    a wireshark trace reveals that both the Status Code and status are present when I run it through the browser
    if I run it from the HC2 in a scene, its not that easy to pick out on the WS trace.
    The request does execute but I'm still getting the debug error
    a little more digging and I think it maybe related to the response for that command
    A normal api command (volume/+2) gives a 200
    Add a syntax error to the url and I get a 500
    but change to the say command and I get the error
    I'm passing this info to the api developer to see what he thinks
    sorted - it was a timing issue
    For a small phase like "Hello" it took almost 50 seconds to pass back a success code and message
    thanks for all the suggestions....
    -f
    -f
    last post..
    there seems to e a minimum response time and encoding the message reduces the time more
    Now I can send a 10-14 message and have the response back around the same time.
    if the message gets longer I'll need to adjust the timeout and I just checked and I can do that on the fly ..
    so all sorted.. the puzzle pieces are starting to come together :-)
    thanks again
    Today I also got an error: Operation cancelled.
    I'm not such a great programmer like @AutoFrankand @petergebruers but nevertheless I never got a warning like this.
    Something new inside our Fibaro-system?
    TRicky
    TRicky
    @TRicky
    where did you get the error ?
    BTW - This is the scene code I ended up with that will help me with my next project
    @AutoFrank,
    That's the part I didn't get. I saw this notification this evening and it was reported around 13:00 hours today.
    At that time I was playing around with my (very simple) auto lights on/off scene so I guess it has to be caused by that scene.
    Strange......
    Just now, TRicky said:
    @AutoFrank,
    Strange......
    @TRicky
    Sounds odd indeed.. my work was new development so it was more my lack of information on the sonos api that a change in HC2
    It was ultimately caused by me not providing a large enough timeout value in a http request.
    I was trying to process the http response status before it was received.
    Are you trying to do something similar with a http request or were you changing the scene when the error happened ?
    @AutoFrank, no absolutely not.
    Just playing around with a very simple lights on/off scene that didn't work (cause of a Dimmer2 with bad reception of the Z-Wave network, as I just found out).
    So absolutely no high end programming.....
    But nevertheless the first time I saw this error, strange!
    @TRicky
    perhaps you could try and recreate the scene or if that doesn't work, maybe a  backup and reboot to see if it clears the anomaly ?
    -f
    Re: timeout
    is there a way to test for valid response from http request i.e. call has processed and error code / status is valid?  I assume http request is non-blocking after the defined timeout limit ?  So rather than adjust timeout value,  "loop" until status is valid value and http processing has completed?
    does that make any sense?
    3 minutes ago, ipsofacto said:
    Re: timeout
    Hi @ipsofacto
    That's an interesting approach. I'd still need to set an upper limit that I can check to see if it has failed or the api is down.
    My apologies - I should have explained what I am planning .
    I'm looking to create a generic Message Hub with the usual notification options like pushover, HC2 email, popup and others but also including TTS. If a TTS fails or another notification method fails  I'll want to send it over analternative notification method and if the internet is down I will send it to HC2 popup.
    .. so this means that I need to provide enough time for a TTS to succeed but also be able to detect if the api is down or if a TTS call is likely to fail.
    .. well that's the plan :-)
