AutoFrank 372
If you are using the sonos-api then you may find this very easy to use VD helpful
It will display the status and volume of each player as well as a house summary of how many are active
The VD below is setup for two zones and is very easy to expand.
Three Step setup
1) Import the VD, amend the IP address for your sonos-api device (port should be fine) and save
2) Add extra players to the table at line 10 (keep name the same as your sonos player/zone name)
3) Add extra labels for each extra player/zone and save. (keep default label format which is Label3, Label4, etc)
Enjoy !!
-f
FILES
Sonos Players Status {v1.0} ----------------------------->
Edited by AutoFrank14 answers to this question
