ianakapilotlight
DENON Plugin not working
I have a Denon AVRX-2300 amplifier.  I was expecting the Denon plug in to work with it.
Having installed the 1.0 version and clicking the search button to find the Denon amplifier, selecting the IP address from the pop up dialog.  The amplifier does not respond to any commands sent to it using the UI provided in the plugin.
Has anyone else experience similar difficulties?
Share this post
Link to post
You will quickly learn that plugins and integration is not Fibaro's area of expertise...
Share this post
Link to post
  • When you make purchasing decisions based on the available plugins and features, those supplied by the manufacturer should be expected to work.
    Share this post
    Link to post
    I agree 100%, but unfortunately with Fibaro that is not the case... Their resources are pooled into marketing rather than development of the features they are marketing...
    Share this post
    Link to post
    as a alternative, you could use the vd  from
    It works on a denon avr-x6300 reciever.
    Share this post
    Link to post
    If it can comfort you, i had the same problem with the official plugin, with my Denon AVR 2100X.
    Using the VD i solved and integration with my HC2 is perfect.
    Enrico
    Share this post
    Link to post
    any hope you can help me with this VD ? the linked website doesnt have it anymore...
    Share this post
    Link to post
    i just tried the link on the website/ it still works.   you have to make a account  and introduce yourself to the community at this link
    google translate version:
    Then you will be able to download the virtual device.
    Share this post
    Link to post
    Hi!
    Sorry to write in an old topic. I have a DENON AVR 3310 and am trying to get this working.
    The plugin for DENON doesn't work.
    I therefore downloaded the vfib file from
    (after I presented myself ;))
    Then I uploaded it to the home center lite, and got this message that I couldn't use the file because I'm using Home Center Lite.
    After this I have tried to set it up manually with
    And then I'm stuck.
    I've tried this:
    TCP port: 80 or 23
    2 buttons.
    STRING on the first button: "PWSTANDBY"
    String on the second button: "PWON"
    Nothing happens
    Can somebody help me please?
    Share this post
    Link to post
    The Denon plugin does not work either. :(
    The link above does not work (even with the registration on the forum). Couldn't anyone have the file to share?
    Edited by Vladimir_st
    Share this post
    Link to post
    Hi Guys,
    Let me positive comment the VD Denon it works with my AVR 3200X.
    I can operate all buttons on the VD and I am surprised that my Denon is listening to all those commands.
    Chapeau!
    Share this post
    Link to post
    I had to present myself in the forum to be accepted to download the link.
    If you have the HC2 (and not the lite version of Fibaro that I've got), perhaps this will work?
    Share this post
    Link to post
