Hello guys
Any news on the Nest plug ins?
Any solution other than IFTT?
On the 4.12 there is no NEST plug ins at all :(
Thanks in advance
Edited by Smartelite
7 answers to this question
At the moment, NEST is not supported. The dev team is still working on the new plugin and getting it aproved by NEST Lab...
On the HC2 you wont find the plugin, however, last week i saw an HClite with firmware 4.120 and the NEST plugin in the list... dont know of anyone else can confirm that ?
    That is sad :(
    I will try to check on HCL and update here
    Is this so difficult? On another blog a user programmed everything in LUA
    Couldnt test on HCL
    can anyone confirm if NEST APP available on HCL and working?
    It is not available on HCL either.
    Plugin will be available, when you will see it in firmware changelog. So, please be patient and let Fibaro developers finish it, certificate it, test it and release it. Not working plugin is worse than no plugin.
    I hope they add boiler support ...
    i have it working whit IFTTT (Set Nest Temperature in Fibaro HC2)
    just make 2 or more scenes in the fibaro and add the code of IFTTT in the luna
