[VD] HC2 Icon preview v2.1
Dear Fibaro friends!
As you know, the worst part of importing and setting up virtual devices is finding icons ID's. How many times you noticed my VD's here with beautiful icons ;-)  , but when you imported it all beauty is gone and there is just that ugly, blue box :-( And then even when you manage to import those beautiful icons of mine :-D then what? In code you have to setup some iconID but where to find that?
Well, the time finally came to put us all to the end of that misery!!! Here it is, HC2 Icon Preview VD in its glory:
This latest version can be found here for download:
Enjoy coding! :-)
Edited by Sankotronic
New version published in download section
  • Like 5
I'll have to get back to you about that example when I get my garage door control hardware installed.
 @clowg
here is another idea for you
This is our Playroom remote control and the icon display the status
TV on
/monthly_2017_04/58f35f3d18aa3_play3.PNG.6b529a3c02b8a4f4e6cb3d05126a3bfb.PNG" />
Music Playing
TV and Music off
and the full remote
Edited by AutoFrank
On 4/16/2017 at 0:10 AM, Sankotronic said:
Hi @AutoFrank,
if @annhan91 agrees I can use some of his code to add more functions to Icon preview VD.
hi @Sankotronic
Yes, you can
    3 hours ago, annhan91 said:
    hi @Sankotronic
    Yes, you can
    Thank you @annhan91
    1 hour ago, Sankotronic said:
    Thank you @annhan91
     I had a quick look at the api and I'm not sure it supports a delete action but hopefully I'm wrong ;)
    You are right @AutoFrank, there is no other action through REST API for icons except getting their info, but @annhan91 is not using that approach but Het.Fhttp to authenticate and then tcp call to play with icons. Very interesting solution! Only I wish now I have another HC2 to play with this code since I don't really want to delete to my working system.
    It seems if I continue to do stuff I do, I will need one developer HC2 with which I can play :-)
    Hi Sankotronic,
    I will also say thank you for sharing all that cool stuff. The VD will save me a lot of time. The icons are not well sorted in my HC2.;(
    The smartest things that work in my HC2  are from you. :D For the translations I was unfortunately too late :( . If you need more translations for the german language in the future I will try to help you. Many many thanks from my side
    P.S. In june i will visit your beautiful country again.
    Thanks @Sankotronic, just used this for the first time.
    Works like a charm and soooo much easier then inspecting elements in Google Chrome!!
    Jim
    Hi @FunkFib and welcome to Fibaro forum!
    I'm glad that you like some of my work. I hope there will be more soon. Regarding translations, there will be more to translate in future so you are not too late and your help will be much appreciated.
    If you plan to visit Croatia in first half of June then you will be more than welcome to visit my humble home if it will be on your way to your destination. We can get in touch over PM.
    Guest andyhud
    Thanks Sankotronic, this is just amazing! So much credit for your hard work!!
    I have created the VD and can scroll through the icons no problems, however can I apply one to a "Device"? I have an Aeon Labs Smart Switch for my Washing Machine and would like to use the Washing Machine Icon (22) for it. Other than saving the icon to my desktop then adding it to the device, can it be added another (and better) way?
    Thankyou !
    Andy
    Hi Andy,
    This current version of Icon Preview can't set icons to other devices or VD. New version of Icon Preview & Setup can setup icons for VD's that are using my new setup system. Unfortunately that new setup system i still haven't released due to some limitations and problems caused by HC2 that I have to overcome.
    Guest andyhud
    4 minutes ago, Sankotronic said:
    Hi Andy,
    Hi Sankotronic
    Understood and thanks for the clarity... so to set an icon for a "device" I can just save the image out of HD Icon Preview and just add it manually?
    Thanks again
    Andy
    Hello, i just try to change the Icons in my VD by using the following code:
       local ThisDeviceId = fibaro:getSelfId();
             debug("silver", 'This devicenumber is :' .. ThisDeviceId);
             fibaro:call(ThisDeviceId, "setProperty", "currentIcon", 1057);
    but i also get the message:
    [DEBUG] 09:48:44: line 51: attempt to call method 'getSelfId' (a nil value)
    can somebody help me - what's wrong?
    Hi @Cannon_82 and welcome to Fibaro forum.
    I can only see problem in second line:
    debug is reserved word in LUA. Do you have function that is called like that and it uses colors? If yes, then there is problem with "silver" color. There is no silver color, but "grey" or "white".
    Hello Sankotronic, thanks for your answer. i use a extra debug function:
    -- debug-function
    function debug( color, message )
     fibaro:debug(string.format('<%s style="color:%s;">%s<!--%s-->', "span", color, message, "span"));
    i use different web-colors in other scenes like "darkorange", "orangered" and many other. These colors were use correct in the debug messages.
    i also try the code in a completely new scene without the debug entry and nothing else. there came also the error.   :-(
    And thank you for the great work. Your scenes and VDs are great - Keep it up!
    Edited by Cannon_82
    formating
    My fault! I try it in a scene, not in a virtual device.   o.O
    Thanks for the help.
    is there any possibility to change the icons of scenes?
    Hi @Cannon_82,
    there is a way to change scene icons, but change will not show until web GUI page is refreshed or network data reloaded in mobile app so there is no much use of it. At least that is information I have.
    This is good idea
    I can only agree with previous speakers that this is a very useful VD! Impressive piece of work.
    On a side note: I am curious about the concept of storing a table in a global variable. This changes everything! I mean, the standard functionality for global variables in the HC2 is quite lobotomized as it can only handle numbers and fixed values, no strings or data structures.
    The mechanism for creating a global variable if it does not exist is an eye-opener for a newbie like me.
    A question then: Are these things documented somewhere so I can read about how this works or have  you used trial-and-error to find out how it works?
    Thanks for the great code and the inspiration!
    Per
    Hi @perjar,
    There is no official explanation of how to create global variables from LUA code but I find a way thanks to help from this forum members. This community here is great and wiling to help.
    I have posted here procedure how to add different types of global variables using LUA code and also how to store and read LUA table data to global variables. You can find that post here:
    BTW that code can be used in both VD Main loop and LUA scene.
    Hope that this helps
    Enjoy coding :-)
