kunoch 27
Hi all,
If you get frustrated when a copied scene does not behave properly.... I had it as well.
situation:
I created a very silly scene controlling a Fibaro relay switch to test some other stuff on my HCL, :
if "device" is ON or "device" is OFF then switch "device" ON (Scene is manually triggered and has no internal trigger -> deselected check-box)
Works perfect when manually triggered.
I copied this scene and gave it a new name and changed it to:
if "device" is ON or "device" is OFF then switch "device" OFF (Scene is manually triggered and has no internal trigger -> deselected check-box).
Guess what. The OFF scene does not work at all, I edited and edited, until I noticed, that the scene is switching the light on, instead of off. I deleted the scene, created it from scratch and it worked. Wondering what went wrong here.
kuno
Edited by kunochLink to comment
