Hi everyone,
Exciting times ahead..:D:D .
.... @fat spotted that the official Fibaro Skill is now available in the Alexa store.
Hi @T.Konopka - Do we need a new hc2 fw release to be able to leverage this or is it usable straightaway ?
Feedback from anybody getting it successfully running most welcome...
-f
PS - I'll be looking this later and will try and create a Tutorial
PPS - Looks like we don't need new fw, anything after 4.112 will work...
Interesting - activate VD through scenes
Edited by AutoFrank
    3 minutes ago, AkilliYuva.com said:
    How can you use Alexa via RPI?
    @AkilliYuva.com
    I use the HA bridge from BW Systems to execute Alexa commands on the HC via the API
    Just now, AutoFrank said:
    @AkilliYuva.com
    Thanks @AutoFrank I'll check that out.
    I'm running HomeBridge on my PI. Is it possible to run both HomeBridge and HA Bridge on the same device?
    @AkilliYuva.com
    HA info here
    .. but I've no experience with HomeBridge :-(
    Guest fat
    10 hours ago, Bezan said:
    That was main reason why I switched to RPI and node sonos http api :)
    I tried to run the Automate Asia version of the HA Bridge that auto imports all devices connected to HC2 but couldn't get it to work with Alexa. I was able to get all devices working in the test function but Alexa didn't discover any items and I gave up
    I've been following the forum on bwssytems concerning the HA and from what I can tell, 4.5.1 is really the last stable update. I wouldn't go any further than that... There has been a ton of issues with the latest updates...
    Its the version that I'm currently using too.
    Guest fat
    I finally managed to get the HA Bridge working!!! I love how fast it works compared to the Fibaro skill. This is awesome!!!!!!!!
    Hi @fat
    Which version of ha bridge are you using?
    Guest fat
    @AkilliYuva.com I am running 3.5.1 that has been modded by Automate Asia to allow bulk inclusion of Fibaro devices
    Hi @AutoFrank,
    Are you using any tool for adding devices and scenes to ha bridge? or are you adding them manually..
    59 minutes ago, AkilliYuva.com said:
    Hi @AutoFrank,
    @AkilliYuva.com
    I am adding them manually but I'm running the normal HA bridge sw
    5 minutes ago, AutoFrank said:
    @AkilliYuva.com
    Thanks I'll try it today.
