Edb 1
Hello all, Ive got these lights
ive fitted a dimmer 2 and bypass ( directly into the dimmer 2 between feed to lights and Neutral). Ive played with pretty much every setting i can find. They have a dimmable driver on them. Now when you flick the light switch they flash on for a second then go off ( same goes for it you do it through the UI ) the next time you flick the light switch they'll come on fine. Ive tried them with scenes and they do the same. Ive got 3 rooms with these lights in they are landing ( 3 lights) hall ( 2 lights) bathroom ( 4 lights) they all have the same problem thought thb the bathroom seems to be more stable at the mo. Is it a light issue or a dimmer setting. Ive just reinstalled the system from scratch so everything is a fresh install and im running 4.120. before i reinstalled some of the dimmers they worked fine, with the dimmer in place but not added to the hc2. Ive spoken to Fibaro and they've suggested, wiring ( its fine, 2 are on 2 way switching 1 is on a one way and ive software disabled the 2way switch and it didn't make a difference) and settings. Has anyone come across this or got any ideas?
many thanks
Ed
11 answers to this question
