A while back somebody asked me to share my darkness monitor/autolights approach I use. (Sorry for the delay but I recently had to rebuild my system)
I took this decentralised approach as some of my house is well lit and some slightly darker at given times of the day.
It is nowhere near as powerful or flexible as @Sankotronic VSL (which is worth checking first) but if you are looking for something much more basic then this might give you some help.
The solution is essentially  3 parts
  1. A VD to track light level in the different spaces and trigger off a defined light level (it used a Process/Update button and Main Scene executing it every 5 mins)
  2. A global variable (1 or 0) for each space you want to monitor .. darkHall, darkLiving, darkOutside, darkKitchen .. etc
  3. A scene (triggered from the global variable ) to turn on the light/lamp when the required light level is reached.
PART 1 - Virtual Device - Darkness Monitor
Each space I want to monitor has a label and a block of code in the Update button code
My full darkness monitor VD looks like this...
My MainScene entry is as follows
It's the 5th entry in the list below.
I'll share the VD at the end of the post
PART 2 - Global Variables
I decided to one per space and not a table as I wanted to trigger the scene from the global variable change.
PART 3 - Auto Lights scenes
I use one scene per space/device you want to trigger
I use a couple of types so I'll share a few examples
I also send a message using the message hub when triggered on as well as using sleepstate.
I also use HomeTable for my id's so replace with device ID's but it makes it a bit more readable
Delete what you don't need ..
Hall
- simple one, switch on lamp ( I also track sleepstate for this one )
Living Room
- check other lights and also check is lamp is on
Kitchen
- same as Living room but this is also motion triggered
Stairwell Light
- Our stairwell doesn't have a window so I check three light levels and determine from that.
I use the following icons as well depending on what is triggering the light/lamp
/monthly_2017_05/58fa1b24dbf44_lightsdoor.png.92ee10273a9c8b23450d8fe593f71a3c.png.09e59e72915b9331c6e8a6a928496c0c.png" />   58fa1b25890a5_lightssunset.png.d03d6bb9c99662e79678de67fe98f68b.png.1cc855002acfcdb142ca24e060ee1da8.png   58fa1b253799c_lightssensor.png.0f976c9e3ca4e37e27b01bc837105cf1.png.feb1fcc7a9728361a8661743559c5cc0.png
VD code attached -
Enjoy
_f
Edited by AutoFrank
4 answers to this question
super but can you add those pic again please
    Hi @confesor, @RH_Dreambox
    First post fixed...
    _f
    Edited by AutoFrank
    Is this a picture of the VD for tracking light level???? It must be wrong picture.
    And please, can you add the code for this light level VD.
    Will do @RH_Dreambox
    The post seems to have gotten all mixed up with files and icons disappearing
    I'll fix the first post in a short while
