obeliks 0
Hi you all,
I installed several Roller Shutters 2 at single roller shutters. Thanks to some of you who helped me out; they work!
Now I have 3 screens controlled by 1 switch with help of Somfy relayboxes. When I try to calibrate the screens, it only turns down 2 cm and than it stops. (The reason is of course that the Fibaro doesn't measure any power anymore, because of the relayboxes, so it stops...)
Do you know a solution?
I read at some websites to link the Fibaro to a manual switch to the roller shutter 2 and a light bulb. Measure the time that the screens need to get down and do the calibration manual in this way.
Someone another solution?
I don't have a HC, I have a Homey...
