I found two issues with the REST API, one with the API and one with the documentation .
The two are separate issues
API
the /api/service/backups is not accessible over local host ip and port
This will work
but this won't return any data and throws an error
yet this will work (different api call)
Documentation
http://<HC2IP>/docs shows the call correctly to be /api/service/backups
The Fibaro developer site shows the call to be  /api/settings/backups and doesn't work
I assume it was deprecated at some stage and the documentation not updated
Regards
_f
Yeah, Yeah...
Fibaro is so well documented....
I'll rest my case.
    43 minutes ago, Bodyart said:
    I'll rest my case.
    LOL as it was the REST API :-)
    • 2 months later...
    @AutoFrank, I have the same results as you. I checked it while using your HC2 Resources VD. By the way, thanks for a great VD.
    I noticed, that this code works also:
    Then you don't need to use IP of HC2.
    Interesting .. Thanks
    What fw are you on..
    I'm running 4.130
    Interesting, I have T_END error while using port 11111, but when using port 80, then it is ok and i result: table: 0x847a3c0.
    My code:
    Guest pablo77
    This VD is very useful.
    Please, could someone write how to create this VD from the start with final LUA code.
    @pablo77
    I haven't had a chance to document it properly yet but this should get you running...
    It uses hometable to reference SMsgH and Smpl Log so comment out if required
    Three steps to get running
    Step 1
    Line 8 enter your HC2 IP and Port - for some reason the /api/services/backup is not working over localhost
    Step 2
    Adjust triggers on line 80 onwards to what you want
    Step 3
    Add entry on Main Scene or move refresh code in Main Loop and set refresh interval
    You should end up with this ...
    enjoy
    _f
    Guest pablo77
    I'm grateful for sharing this VD.
    I'm just gonna add, that to proper running should be added "HomeTable" in Variable Panel.
    Thanks again
