thomas.hvindenhaug 4
Hi, Iḿ fairly new to programming Fibaro HC so I would very much appreciate some assistance from the Fibaro community.
Iǘe set up a HC2 4.131 in a summer-cabin built up from four small wooden houses. two of which have their own bathroom with underfloor heating controlled by Thermofloor Multireg.
In the living rooms I have used Fibaro wallplugs with aeonlabs multisensor together for controlling electric wall-mounted heaters. When adding the wallplug to the system the
setting for "Controlled Device" default to lighting. Does this parameter affect the ability to make the wallplug a suitable component to be a part of a heating panel?
Will AeonLabs Smart Switch have an option to set the "Controlled Device" to some sort of heating appliance?
Is there a VD thermostat, made up from wall plugs and multisensors, available for download?
Thank You
