Hi
I (foolishly :-) ) offered to outline how I create icons using GIMP so here goes...
Disclaimer - I am not a graphics designer and I'm sure there are better ways to do this but this is what I do
if you are a graphics designer - please be kind :-)
INTRODUCTION
Using GIMP to create a Fibaro icon (128 x 128 px png with transparent background)
This is about working with images that are already created.
It’s important to remember that the background in both the webui and apps is dark so I dark image will probably not work well
I always start my research on the internet for an png image that has a transparent background
Failing that I try and get one with a white background with sharp edges (high contrast) to the background
Be sure to observer image ownership rights and use only those that are free to use
Let me take a couple of examples
EXAMPLE 1
Sonos Soundbase
Google search with images
The first one on the second line looks promising. Click it
The checker board pattern indicates that this has a transparent background
Right click and save and you have a 400 x 400px png image with transparent which is perfect
It just needs to be scaled
Download the image
Open image in GIMP
There are two dialog boxes that are useful and sometime get hidden or closed
Toolbox – selection, painting tools and lots of other options
You can find this under the Window Menu in GIMP
The second one is the Layers and Gradients
You’ll find this under the following menus in GIMP
Windows – Layers and Gradients
Ideally you should have these two open when you work in GIMP
Our example image just needs to be resized
Click Image – scale Image
Change the size (400 x 400) to 128 x 128px
Then we need to Save
Click File and either .
  • Export – and add a name
  • Overwrite– to save the file with the original file name
Export
Give it a name and location and leave the png file extension and leave the final dialog box default settings
Click Export
Overwrite
If you select – Overwrite , remember to discard changes as you save ( otherwise the image will close with no changes)
 .. and that’s it – you now have a HC2 icon
EXAMPLE 2
The second image is also transparent png but an odd size (425px x 331px) and we want to remove part of it
There are lots of ways to do this and I am not a graphics designer but this is the way I would do this
Starting Image here
Open in in GIMP
The image is right out to the edge so I want to create some space and I do this by adjust the canvas size
The canvas is what the image sits on and adjust this will not scale the image.
If the canvas is reduced it may drop the image
So lets adjust the canvas to start getting rid of the text
Image – Canvas Size, try 250 wide and if you ignore the text it approximately centers the battery image in the middle. Click center to shift the image and it should look like this
Click resize and you see this
Lets get rid of the text
On Toolbox. Click eye dropper
Click this and clikc somewhere on the grey
And this selects the grey colour
Click Paintbrush
 And start to paint the grey over the white text and fill in the two top corners with grey ( as rounding is a bit beyond this small tutorial)
We need to get rid of the lower part of the canvas
Click Layer – Layer to Image Size
So now we have an image we need to resize into an icon
I like a little space around my image so adjust the canvas
Image – Canvas Size, enter Width 450 and height 450
Click Center and Resize
This gives us a square image with a transparent background canvas
Now we need to scale to 129 which is what the HC requires
Image – Scale Image
Enter 128px x 128px to resize
And then export or overwrite under File and you end up with this icon that can be used in the HC2
EXAMPLE 3
The last example is using a jpg image that is not transparent
This may not work with some images if the background color bleeds into the image too much
Lets take this final image of a box - white background
Open In GIMP
We ned to make the background transparent in a step called Colour to Alpha (alpha layer is the transparency in an image)
Under Tools – select Colour to Alpha
The colour that it will turn transparent is White and you can see the preview
Click okay and you see the change
Next we need to make it square with a Canvas Size (under Image)
Image is 724 x 665
Adjust height to 724 and select Center to square it
Next resize it as above
Image – scale Image to 128 x 128 and export or Overwrite
And we have another icon read for HC2
If you have started with a jpg – then complete the same steps and when it comes to Export, select Export as a png
EXAMPLE 4
Now one for you
Take this image
 and turn it into this icon that is HC2 ready using the techniques above
Hopefully this helps you in creating your own icons
Enjoy
Edited by AutoFrank
I could never work out that colour to alpha bit so that solved another puzzle for me .
Thanks Frank
Edited by Jamie mccrostie
Thanks @AutoFrank for this very useful tutorial!
@AutoFrank
Works perfect!
I use Gimp from time to time, but am not a Gimp power user.
Good stuff I find are saved as PDF:s in my archive. This tutorial is saved... :)
/Peo
  • 4 weeks later...
  • T.Konopka featured and pinned this topic
  • 4 weeks later...
    On 7/27/2017 at 10:00 AM, Captain Chaos said:
    Thanks for sharing, will give this a go today!
    How did you get on @Captain Chaos
    Any suggestions for improvements ?
    • 4 weeks later...
    Not very well to be honest haha.
    Need to give it another go when I get time.
    • I.Srodka unfeatured and unpinned this topic
