djsnix1986 0
I've set direct association of Fibaro Motion Sensor and 2 x Fibaro RGBW controller in HC2. Set to Group 2 single channel per each. I can't solve the issue of brightness - it turns on the minimum level only. I need to manually turn the brightness to max. But when turns off and on again - level is again minimum. How can I set brightness in direct association? Parameter 14 on Motion Sensor is set to 255. Looks like I'm missing some important part!
Thanks!
