My rack has been running hot for a while and this project is a little overdue. I decided to make my own cooling device
3 x 240V 20W fans, some plastic trunking and glue and tape, fibaro dual relay, 3 hrs and a little swearing from time to time :-)
It vents through the ceiling to and outside space.
Final construction
in place now and working well
hope it inspires others to roll up their sleeves
_f
@AutoFrank great project. Does it also suck out the bugs? :P
Guest fat
Nice work. I just cut a hole in my ceiling and have put in a ducted inline fan. The benefit of this was that I mounted the fan in the ceiling above my bathroom to keep the noise away from my media room where my goodies cupboard is
    unfortunately not .. I'll try and build that into a phase 2 :-)
    Thanks @fat
    I started this route but access is difficult and the inline fan I got sounded like a 747
    The three fans I use are very quiet but our goodies are in the utility room so noise is not an issue
    The kids called it the funny looking gren elephant :-)
    Can I recommend the "Qubino Flush On/Off thermostat" instead of an ordinary relay? This device has a GUI bug (pun intended, see my previous post) on a HC, but I have a script to work around that.
    The advantage: this is a standalone thermostat, it'll work without command from a controller. I own one.
    I have tapes in ANY available colour, but not THAT GREEN!
    Now I am jealous!
    :-D
    Thanks @petergebruers
    I must get my hands on one of those
    update
    Just ordered one
    Edited by AutoFrank
    @AutoFrank here is the code to fix the GUI. EDIT: I own the non Z-Wave Plus version of this sensor, I'm not sure the newer model needs this code. Also, the newer model has a lot more parameters.
    If my memory serves me well, it has to with the fact that some factor of 10 is required when you set the temperature (so the set point is in deci-celsius, not celsius). The GUI sends degrees. So 20 degrees gets interpreted by the module as 2.0 °C. The device reports this, the script detects this and the script sends 200 deci-celsius instead. Then, the device goes to 20.0 and reports this, so everybody happy. I could me making this up. But I like this explanation. ;-)
    Edited by petergebruers
    should have it early next week...
    What about this solution ;)
    • 4 weeks later...
    Hi @Patrick
    Where did you acquire the heatsink ..
    It's a monster :D
    All...
    I did purchase a quibino with temp probe but had issues including it so I went a different direction...
    I decided to head back down the UBS route with two 1 wire temp probes with one above both racks and a vd button running on a 10 minute schedule
    Edited by AutoFrank
