AutoFrank 369
I was recently told by fibaro support that my aeotec smart switch was one of the busiest in the zwave network.
My was excluded from polling so I wanted to see how people had set theirs up and if they changed the default values
This is how mine is setup and I was wondering if anybody had some tips
Polling : Exclude from global polling
Parameter 3 Current Overload Protection
Load will be closed when the Current overrun (US: 15.5A, other country: 16.2A) and the time more than 2 minutes
0 - disabled
Parameter 20 Output Load Status
Configure the output load status after re-power on
0 - last status
Parameter 80 Notifications to associated devices
Enable to send notifications to associated devices (Group 1) when the state of Micro Switch’s load changed
1 - hail status
Parameter 81 Configure the state of LED
Configure the state of LED when it is in 3 modes
0 - The LED will follow the status (on/off) of its load (Energy mode)
Parameter 83 RGB value
Configure the RGB value when it is in Night light mode.
0 - 255 -> Set the indication value of red Led.
256 - 65535 -> Set the indication value of green Led.
65536 - 16777215 -> Set the indication value of blue Led.
0
Parameter 90 Enable/disable parameter 91/92
Enables/disables parameter 91 and 92 below
1 - enabled
Parameter 91 Report of minimum change in wattage
The value here represents minimum change in wattage (in terms of wattage) for a REPORT to be sent.
25W
Parameter 92 Minimum change in wattage in percent
The value here represents minimum change in wattage percent (in terms of percentage) for a REPORT to be sent.
5%
Parameter 101 Which reports need to send in Report group 1
Auto send Meter REPORT (for voltage) at the group time interval
Auto send Meter REPORT (for current) at the group time interval
Auto send Meter REPORT (for watt) at the group time interval
Parameter 102 Which reports need to send in Report group 2
Auto send Meter REPORT (for kWh) at the group time interval
Parameter 103 Which reports need to send in Report group 3
nothing set
Parameter 111 Time interval 1
The time interval of sending Report group 1
120s
Parameter 112 Time interval 2
The time interval of sending Report group 2
3600s
Parameter 113 Time interval 3
The time interval of sending Report group 3
600s
Parameter 200 Partner ID
0 - Aeon Labs Standard Product
10 answers to this question
