Connecting Multiple Dimmers to one switch
nabilw
I have multiple dimmer led strips in my living area which i need need to control as a single light but exceeding the load of dimmer 2. can i connect one light switch to 2 or 3 dimmer 2 module to control my lights.. all led light and dimmable drivers are of the same type. in other word can i use one light switch to control (send signal to) more than one fibaro dimmer 2 at the same time.
First something else. You say LED strips. Are they specified as dimmable? Do yu use a mains dimrer now? You have some datasheet? Are they 220v or 12v? With an adapter? I' am asking this because a RGBW module might be a better or even the only working solution. A link to the product datasheet might help to understand this. How many strips do you have and what is the total power?
If yu need two modules, because of power rating. I'd connect the switch wherever you want and use a (magic) scene to sync them
For RGBW one can buy extenders. But not for 220 V dimmers.
