Automatic Change of Language from EN to ET
Guest chaicka
I am not sure if this behaviour started with 4.134 or 4135. On a few occasions, the web GUI has automatically switched from En to Et. Just happened again and it was after performing a backup and the GUI refresh to language Et when it completed backup. Is anyone else experiencing similar behaviour?
7 answers to this question
" to "
Temat został przeniesiony z "
" do "
No, we did not encounter any such behavior.
Do you remember when it happened beside after creating backup?
Hi @chaicka,
Could you check which languages are detected in your browser by PHP?
/monthly_2017_09/59ad06e2a8927_BrowserLanguageDetection.PNG.86102291d3e93c4abbaaf1ce5b4cbfec.PNG" alt="59ad06e2a8927_BrowserLanguageDetection.PNG.86102291d3e93c4abbaaf1ce5b4cbfec.PNG" />
Maybe your browser identifies itself wrongly?
Another probable cause for such behavior may be the fact that you copied some LUA code, or downloaded the VD which has a reference to ET language:
Guest chaicka
    6 hours ago, I.Srodka said:
    Hi @chaicka,
    I do not think so as I have only encounter this intermittent/random wrong language issue with Home Center, no other websites or appliances have I encounter this. Attached is the screenshot of language detected.
    It is quite unlikely as I have not copy or add any new scenes or VDs for a long time (way before 4.13x series). I can run a check but I generally do not copy and paste entire piece of codes into Home Center. Even if I do reference, I will use text editor to line by line construct and understand part by part what it does. That way, I won't accidentally create a mess without knowing where to look or how to troubleshoot. I also generally hate using hard-coded lines in scripts or programming. The only time I think I did with any codes in Home Center is for reference to image file on Home Center such as push notification or interactive notification to use a particular icon/image on Home Center.
    Edited by chaicka
    @chaicka,
    It is possible it might be just a temporary issue.
    Could you change the language in General to English (even if you have English), and see if this happens again, from this moment?
    Guest chaicka
    3 hours ago, I.Srodka said:
    @chaicka,
    It has happened more than once, hence posting. And 4.135 is not the first time it happened.
