[SOLVED]Interactive push in block scene
Edited by I.Srodka
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
Hi @systemfel,
Could you elaborate on your problem?
I do not know what are you trying to achieve.
    I can not change which scene I'm going to use in the dropdown menu across scenes. It's always the top scene that appears no matter what I choose. Last menu where I dialed the picture. More than i should have this error ..
    Was a solution found for this?
    I am also not able to choose which scene to run anymore. The scene on top of the drop down menu will say put, no matter which one I choose.
    It used to work fine. I have HCL with 4.170 firmware.
    I thought this might be due to scenes having their names changed.
    In other scenes, where I already had working interactive pushes, I could actually choose between scenes that does not exisit anymore... and they worked.
    Could be a memory issue perhaps.
    I deleted all these old interactive pushes, hoping that I could now setup up interactive push correctly, but that did not help.
    My intent was to send interactive push to my wallmounted ipad, running the Fibaro app 24/7.
    Learned afterwards that the ipad will not show any notification when the Fibaro app is in the foreground... and now I have no interactive pushes for anything.
    A typical day trying to do something in Home Center...
    I got a scene mismatch after updating to firmware 4.170. I resored last backup and it seems to work correctly now.
