Guides for the Forum Read more... ×
Poradniki na Forum Read more... ×
FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
ianbren
Connecting Fibaro HC2 to an ESP8266 - two tutorials
Hi, I've had a few questions on how to use Fibaro HC2 to talk to ESP8266 devices.
If you're interested, the simple example over at
can help.
there are two assumptions
- that you can create a Virtual Device in Fibaro and have used LUA before
- that you've got the Arduino environment to build and ESP8266 (of whatever flavour you want).
Basically, the solution has a Virtual Device with one button - press the button in Debug mode and the ESP8266 is called and returns with some JSON.
If there's interest, I'll expand the examples to include one for ESPEASY and a DHT11 - where you can build wifi-enabled temperture devices.
Cheers
Ian
Edited by ianbren
change of title
Share this post
Link to post
  • 201 is also posted now at
    Shows how a Fibaro HC2 can poll an ESP8266 and receive JSON data back - then post it to a label.
    This is a work in progress and if there's interest I'll move on to ESPEASY - to monitor temperature.
    Share this post
    Link to post
    JFYI:
    1) ESP8266 Serial ESP-12F Wi-Fi Witty Cloud Development Board + DHT22
    2) Code TemperatureHumidity.ino (see attach file TemperatureHumidity.ino)
    3) FIBARO VD (see attach file Climate_ESP.vfib
    Edited by 10der
    Share this post
    Link to post
    On ESP8266 board You have Light sensor ( that thing in upper corner). Are You not using it in the skech ??
    Edited by pablo77
    Share this post
    Link to post
    Perhaps you failed to pay attention to the arduino sketch file.
    notice:
    const char* WIFI_PASS = "id2891Sz500Qp";
    it's fake WiFi password :) but in any case - thank you and welcome to my home and Ukraine :)
    Share this post
    Link to post
  • I like the Code - some suggestions...
    (a) - you calculate Dewpoint - but don't return it in the HTML.
    (b) the calculation is deferred every 15 seconds (in the main loop) - perhaps pull the constant out to the top to make it clear what's happening.
    (c) you might want to consider starting up the DHT/reportreading  before calling the server.begin() - as it stands the HTML strings (humidityString etc) are empty and Fibaro may start polling before the first read.
    Oh, and I love the icon model.
    Oh, and I found the WITTY useful for the LDR, but getting access to the Digital pins is a pain for anything other than experimenting.
    Have a look at WEMOS D1 Mini - they're about the same price, the same form-factor but have Shields (only the DHT11 in this case)
    Edited by ianbren
    strike through on (c)
    Share this post
    Link to post
    a) yep! you're right. I was thinking later what it's useless :)
    b) yes. :)
    c) arduino does not start loop thread while setup() void not done :) + server.handleClient(); last command in loop - all requests from HC2 going to /dev/null :)
    Quote
    but this sandwich pretty good! (IMHO)
    Quote
    yes, I know.
    see also:
    WeMos D1 mini DHT11 shield
    WeMos D1 mini DHT22 shield
    WeMos D1 mini OLED 0.66 shield (
    WeMos D1 mini TB6612FN (motor driver) shield
    WeMos D1 mini button shield
    WeMos D1 mini relay 5v shield
    WeMos D1 mini LED ws2812 controller shield
    Share this post
    Link to post
    - good point - and the variables are populated before that.  So scrub (c)!!
    Share this post
    Link to post
    as Another ideas...
    Arduino sketch
    here are results:
    so, now ESP poll FIBARO if events occurred
    ESP call fibaro scene and pass some parameters.
    pay attention: we can use one single scene for many external callers - a simple pass to the scene for example Id or action etc
    btw, in the scene we can pass a table as well:
    for example
    fibaro result:
    [DEBUG] 02:14:52: actions
    [DEBUG] 02:14:52: table: 0xa133818
    Share this post
    Link to post
  • I've seen this before - it does split the logic between the ESP and the Fibaro - but this approach pushes the FB-specific actions into the Scene.
    Share this post
    Link to post
    First of, thanks for the info. It was realy helpfull thusfar. Perhaps you can help me a littlebit further.
    I'm building a touchscreen based on a Nextion display and a ESP8266 Nodemcu chip. I want to make a wall controller for my Homecenter 2. I can already send data from mij ESP8266 to HC2 to start a scene or switch a device. And i can send the GET command from my HC2 to the ESP in order to start a void there. (With your code) I was wondering, is there a way that i can send the status or brightness value from my HC2 to a int in the ESP? I'm trying to figure it out for a while now and can't seem to fin a good soulution.
    Greetings,
    Damien
    P.S. Sorry for my English, not my native language.
    Share this post
    Link to post
  • well, the simplest way would be to pass it as a parameter.  If you have the ESP8266 libraries installed, there's an example called "advanced web server".  It shows how you can pass page requests to the ESP and have it break them down.  Look for
     server.on ( "/inline", []() {
      server.send ( 200, "text/plain", "this works as well" );
    If you want to pass a parameter something like this for "i" and "s" --- http://someUrl/myPage?i=5&s=20 --- then it get's a little more complicated.
    use a line like
     server.on ( "/myPage", handleMyPageHere)
    then have a function
    void handleMyPageHere(){
    int myVar1, myVar2;
      if (server.hasArg("i")) myVar1 = (server.arg("i").toInt());
      if (server.hasArg("s")) myVar2 = (server.arg("s").toInt());
    // do something interesting with your variables.
    Obviously scope of the variables is important.
    Maybe the return string is the response that Fibaro is waiting for.
    Have fun!
    Share this post
    Link to post
    " to "
    Temat został przeniesiony z "
    " do "
    Share this post
    Link to post
    I want use esp8266 for 2 relays for my garden watering. With Raspberry Pi and Domoticz all working. But i want use these relays with Fibaro.  It is possible and how ?
    Share this post
    Link to post
    insippo, I had some success using EasyESP and have a scene calling the EasyESP REST API.
    - Check the EasyESP docs for API, you will have to set up a task for this.
    - Here in the forum you find numerous examples how a Fibaro scene makes a call to a REST API.
    Cheers,
    jayrock
    Share this post
    Link to post
    A little off topic perhaps...
    I have some d1 mini's flashed with Tasmota and it exposes a web interface... very easy to get it to interact (status/ control) with the hc2 with a vd.
    Only downside is that it is over http (not https) . It also exposes an mtqq interface which is more secure  but with no HC2 support I have not played with that part... ....yet
    Share this post
    Link to post
    btw:
    about tasmota
    Edited by 10der
    Share this post
    Link to post
    Hi there,
    I am trying to connect Weatherman (
    Nice weatherstation....
    Controller is based on ESP8266. Communication with browser is fine showing data.
    Try to get json with VD based on
    Got Status=200 and Error=0 but response (should content json) seems to be "empty", using Port 80.
    Any idea?
    Best regards
    Michael
    Share this post
    Link to post
    @miwa ["Content-Type"] = "application/json",
    in headers
    also see:
    ["Accept"] = 'application/json',
    Share this post
    Link to post
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
