I am a newbie, so I do not know how to handle your hint.
This is what browser shows....
ok.
let's first provide your code here
Started to create simple VD... just to get json
local thisdevice = fibaro:getSelfId()
-- the next line uses the VD information on the ESP8266
-- to create a HTTP connection object
local conn = Net.FHttp(fibaro:getValue(thisdevice, 'IPAddress'), fibaro:getValue(thisdevice, 'TCPPort'))
-- if there's a path name, then put it in the GET() method.
response, status, errorCode = conn:GET('/json:')
-- "response"  will hold the JSON coming back
if response == nil then
  fibaro:debug('response  = nil ')
elseif response ~= nil then
  fibaro:debug('response  ' .. response)
fibaro:debug('status  ' .. status)
fibaro:debug('errorCode   ' .. errorCode)
-- good practice
fibaro:sleep(1)
if errorCode == 0 then
    -- so , you got something back ok
    -- the Status is not really needed, unless you're going to deal with non-200 HTTP Status codes
    -- Example processing JSON
  -- fibaro:debug ("Try to get table")
  jsonTable = json.decode(response)
  --fibaro:debug (json.encode(response))
  -- there are three elements that come back in the "101" sample ESP8266 code
  --fibaro:call(thisdevice, "setProperty", "ui.Label1.value", jsonTable.w_temperature)
  --fibaro:call(thisdevice, "setProperty", "ui.Label2.value", jsonTable.Data2)
  --fibaro:call(thisdevice, "setProperty", "ui.Label3.value", jsonTable.myText)
else
    -- so we had a non-zero error code - something went wrong
  fibaro:debug("Error: Code  " .. errorCode)
so, it's VD
AFAIK(R) custom headers available... only in scenes, not virtual devices.
hmm... do you have an example how to  get json be a scene?
Ok, got the solution....
I do not find solution how to send http://192.168.1.1/control?cmd=GPIO,12,1 command to esp8266 with Espeasy. I create virtual switch on hc2 and tryng send this but without luck.
  • 4 weeks later...
On 9/20/2017 at 1:23 PM, 10der said:
JFYI:
1) ESP8266 Serial ESP-12F Wi-Fi Witty Cloud Development Board + DHT22
Hi 10der@,
Coole script!
i have qestion, can i take multiple sensors on the same board(total 3), and youse it on fibaro as a different sensors for different rooms?
Best regards
not clear for me... why not? :)
but, one notice VD is not Z-wave device and you can't use it as default sensor in Fibaro  UI, etc
Thanks for so fast answer!
I am not so good with coding and use mostly copy, paste function.;)
Sensors will be used in basements in different rooms to monitor temperature, and humidity, and start scens.  I guess in
need to change
// Connect DHT
DHT dht(D1, DHT22);
DHT dht?(D0, DHT22)
DHT dht?(D5,DHT22)
but what i need to change in VD to know a value from different sensors because is on a same ip adress?
Thanks..
first. i still not clear understand you =)
1) (let) I have 5 (five) DHT sensors on my Arduino
2) (let) this Arduino is ESP8266. Otherwise, you should connect Arduino via  0/1 pin to ESP to 1/0 pin as COM
3) on ESP create Web Service. (let) for example, Arduino have 192.168.1.77 address and WebServer port is 80
4) code Arduino www handler and endpoint /sensor and /1 /2 /3 /4 /5 - endpoints for DHT sensors data
5) VD in HC2:
NB: the provided code I was wrote here in this forum html editor. so, it can don't works :)
  • 10 months later...
Just stumbled upon this thread and hopes one of You guys can help.
I am using my fibaro system also as an alarm system for my house, but would really like a better way to know if the alarm is armed or disarmed.
I recently bought a Wemos D1 min and a 0.96" oled screen for another project and is now wondering if it would be possible to get the Wemos to retrieve a GlobalVariable value and present it on the screen??
Example: When alarm is armed the display states "Alarm Armed" and "Alarm Disarmed" when the alarm is not armed..
I have no knowledge of coding, so this is where i need a little help..
Is this in any way possible??
1) this OLED will dead after 1-1.5y with artefactes etc (just fact, I have 2 OLED with same results)
2) yes you can grab global values. for example
where 192.168.1.36 - HC ID address
AlarmStatus - your global value
and do not freget provide basic auth header
good luck
Thanks a lot for your fast reply.. :-)
The Oleds are so cheap, so it would be easy to replace them if they die out..
Is it possible for your to help me with the actual code, I have to flash onto the Wemos? I have absolutely no knowledge of the coding..
At the moment i'm using the present Wemos as a monitor for my 3D printer (using this code).. I assume the code for what i want here must be a mix of this and some of that You have written here in the forum a couple of posts up?
  • 3 years later...
Hello
 I have quickapp in HC3 that have some buttons I want to call from ESP8266 with it's URL All buttons API is working fine in browser the project consist of {ESP8266, IR Receiver} that is it I want to make conditions for the buttons that IR receive I will get it's HEX from serial monitor and every button it's condition come true is calling Certain button in fibaro quickapp through API How can I make API call under every (condition) OR (case) from arduino
  • 2 months later...
maybie something here can help :
It shows esp code as well as very basic fibaro device.
Edited by vifefref45
