Fibaro compatible devices list
 thank u too.
I have a question, but i can not find the answer on any forum.
Maybe u can help me.
I need some list of compatible devices with fibaro.
I mean, for examp. i need to find best Thermostat for Fibaro, and i know that Nest, Ecobee, Honeywell and so on is available on market.
So do Fibaro have some list, to see all devices?
5 answers to this question
To my knowledge, there is no such list.
I use Danfoss LC12 and LC13 TRV and no central thermostat, only radiator valves. These products are getting old (but LC13 is OK). New products are coming to the market and I have pre-ordered the Fibaro TRV. It has an optional, separate temperature sensor. If you used radiator valves, you do not need/want/use a central thermostat. The valves do all the work and adding a room thermostat fights the TRVs!
That is about all I can tell you about heating. I am a humble end-user...
Edited by petergebruers
    Yes, i know about Radiator Thermostats,
    but the problem is, i need wall mount thermostat like nest or 2gig C100 which can control also my AC snd Ventilation
    Sorry, I do not have a clue... I do not use such a device and I do not follow posts on this subject... For what it is worth, some mention their HVAC controller has an HTTP interface and they write scenes and make virtual devices to interact with it.
    Thank you for feedback any way. Will look forward for answers:)
    But I think, campatibility list is very nesceserry for Fibaro.
    Hi @Idrak,
    The only list of compatible devices I know is on Vesternet webshop:
    but they are also not updating it regularly so it must be taken with caution. Good source of this information are forums but requires some time and a lot of searching.
