Why does this block scene trigger (when it shouldn't)
janroger
Why do I get push notifications during the day if the garage door opens with this block scene? (attached screenshot).
The sensor is a Vision tilt sensor..
Converted to LUA it looks like this:
Guess I would be better off if I could make anything out of this LUA code...  :-/
//JR
according to the block scene you shouldn't.    according to the LUA translation, "
you should get notifications whenever the scene is manually run or HC2 reboots.
delete this part from the LUA scene and see if its ok
