AutoFrank 372
Hi folks,
v1.5 of the api is now available on GIT, (just take the latest master)
This version contains a number of fixes and some enhancements including some changes to the clip feature
The list can be found here
In previous releases the /SAY/ command could get cut off early before it finished or not play at all especially if you had a long sentence being spoken
I have been testing the fix for this in v1.5 over the last few days and it would appear to be resolved
Upgrade as follows (if running tha api on a pi with Raspbian image)
log into pi (normally pi and then raspberry)
rename your existing api directory to node-sonos-http-api-old
Clone the latest api master branch from git and place in new directory called node-sonos-http-api
Copy your settings.json file from your old to your new api folder
Download the necessary dependencies
Move back to pi home directory and reboot
The new version of the api should be running and can be checked through a browser if you wish
enjoy.....
4 answers to this question
