Hello!
We need feedback about time synchronization and drifting.
Some of you confirmed that there was a slight improvement with 4.136, but this has not solved the issue completely.
How about 4.140 and 4.141?
Please, state the version of your system in your posts and how much the time is drifting or if it is not drifting at all.
Thanks! ;)
HCL, 4.140
I had a drift of about -8 minutes over two months in manual setting
Edited by kunoch
Guest skarotech
Mine has a drift of 2 minutes after a reboot 3 days ago...v4.140
as someone how has worked in IT for many many years, this is the whole idea around using NTP. While Fibaro has a NTP setting, why is this not checked and adjusted on a daily basis? Perhaps it is and there is another major issue causing the drift ?
Edited by skarotech
HC2 (testing unit 4.141 beta) -> + 1,5 minutes after restart 5 day ago. Using ntp server: ntp.nic.cz
HCL (testing unit 4.141 beta) -> - 6 minutes after restart 4 days ago. Using ntp server: ntp.nic.cz
HCL (showroom 4.140) -> -2 minutes after restart 5 days ago. Using ntp server: ntp.nic.cz
4.141 Beta , time download from internet setting, uptime: 1d, 20h, 45m
Time on the HC2 is 43 seconds ahead of internet time now. (ntp server setting: pool.ntp.org)
HC2 4.140
Manual timesetting since 5 weeks.
No drift at all.
Time is stable.
4.140 - 5 mins slow even after reboot set on automatic time.
HC2 4.140
Timerdifference 4min. + after 4 weeks without syncronisation.
HC2 4.140
Uptime: 12d, 21h, 27m
Download time is ON
Time drift: + 2m, 40s
HC2 - 4.140
Up time  2d, 21h, 31m
Set date and time = manual settings
here is my debug information from the system:
[DEBUG] 21:59:27: Time Synchronization [200] [0] Drift = 59 Sec. [ 00:59 ]
[DEBUG] 21:59:16: Time Synchronization [200] [0] Drift = 71 Sec. [ 01:11 ]
[DEBUG] 21:58:58: Time Synchronization [200] [0] Drift = 83 Sec. [ 01:23 ]
looks like time drifting 12 seconds per day !
I've noticed that time drift depends on system load... have added scene that runs every 35 seconds and drift increased.
Edited by cag014
Guest cuprum
Feedback - initially i think, i asked it from You ;) There was simple question: Is there some plans to implement *standard* solution - NTP*D* (daemon) based one - in Fibaro boxes?
PS. For me personally also "no" is also acceptable answer, with short explanation, like no room on disk.
HC2 4.140
14-20 sec by day, depends of system load
HCL, no time drift.
/monthly_2017_11/capture20171103101927125.png.3c0b6ae995bac95458d684d2def72419.png" alt="capture20171103101927125.png.3c0b6ae995bac95458d684d2def72419.png" /> capture20171103101951097.png.f7ed10e30b80532c1d5c3c10aea03273.png
My HC2 on 4.140 with NTP settings enabled after 5 weeks is now 10 minutes ahead of real time! It was rebooted two weeks ago by my wife because it stopped working (get frozen), but that didn't help to reduce this time drift difference.
It seems like my HC2 is one of the kind with time drifting! :-(
Unfortunately I don't see that anything new is done with this two new betas regarding this problem. Shame! :-(
Which NTP server are being used, by each others setup? Would it change if the NTP Time server will be changed?
Server Status:30d, 22m
35 seconds behind after 1d and 21h from last restart on v 4.142 - HC2, the gap is increasing every day forcing me to restart device periodically.
Guest cuprum
Unfortunately not ;(
Actually, we do not know full information, but seems, that HC is syncing time only when it reboots. So, if Your box is near-to-real aft reboot the time server does not matter anymore.
Yep, there is little possibility, that configured server does not answers and the fast-drifting default time from RTC is used - but this situation is detectable easily with comparing times after boot. If the time is then quite realistic, then server-change clearly will not help. If differs - yep, change may help.
PS. most of time-servers are actually "pools" anyway, so even when multiple times attempt to sync from the same "timeserver by DNS name", it's really mean times from different physical clock devices
3 minutes in 12 days after setting it manually on v 4.140 - HC2
typical drift of this intel board is 13min/year at 25° (2sec/day), plus 3sec/day for rtc crystal at 40°, gives 4-5sec/day.
Unfortunately i rebooted my test system 3day ago without writing down the collected values, but since then the drift is at 6sec/day (board / cmos bat 18months old), which is ok.
