When i am trying to arm (fibaro HC2) the door sensor V2  i get a message that it failed because certain  devices not fullfill certain conditions.
There seems to be a problem but totally unclear to me what the issue is.
Has somebody any idea what could cause this issue? How to find out what the issue is?
I can force the arming but is this then ok, no issue anymore?
    I have done some tests and apparently you can not 'arm' whilst the status of the device is not 'save'.
    I closed the door and then no problem to arm.
    Problem solved
