Showing results for tags 'door window sensor'.
Found 6 results
  1. Hello, Does anyone know any rechargeable battery that is compatible with Door/Window Sensor?
  2. Hi I have strange behavior of door windows sensors from Fibaro, with both old and V2 versions When opening a door and then closing it within about upto 30 seconds or so the "closed" status is received with a 10 seconds delay by the HC2 So the door sensor shows "closed" in the HC2 interface exactly 10 seconds after closing and scenes triggered run accordingly. Open status is always, always received without delay!!!! I have a HC2 with 95 physical sensors, zwave traffic is on average each 6.5 seconds (zwave monitor) Can some one help me with this? I am stuck
  3. I want to control my garage door using Z-wave. I’m thinking about a Relay Switch combined with a Door/Window sensor. I have two wires coming from my garage door opener today. I guess I need a power supply for the Relay Switch. What kind of specification do I need for this? I have a standard wall outlet nearby which I can plug into.
  4. Hello, I have excluded a device from the Alarm system and yet in the Alarm Panel it is still displayed? Please advise
  5. When i am trying to arm (fibaro HC2) the door sensor V2 i get a message that it failed because certain devices not fullfill certain conditions. There seems to be a problem but totally unclear to me what the issue is. Has somebody any idea what could cause this issue? How to find out what the issue is? I can force the arming but is this then ok, no issue anymore?
  6. Hi, I've got a Fibaro D/W sensor (new Zwave+ version) to which I attached an external temperature sensor (the DS18B20: https://www.sossolutions.nl/waterproof-ds18b20-digital-temperature-sensor-extras?fee=4&fep=3315?utm_source=shopping&utm_medium=adwords&utm_term=Waterproof DS18B20 Digital temperature sensor + extras&utm_campaign=shopping&gclid=CMGR0-Xer9ECFZG6Gwodv0QPXw) It does measure the temperature rather well, but what's strange is that it fluctuates with a pattern. Attached images show what I mean. I heated the environment of which I measure the temperature. The temperature is gradually rising, but as you clearly see almost every 30 minutes or so (sometimes longer, sometimes shorter) the sensor gives me a temperature that's lower than expected. And what's strange about it is that this reported lower temperature is exactly the same for some hours and than suddenly rises to a new level that keeps constant for some hours. Does anyone has any idea how to solve this? regards, Theo
