I tried to ask Fibaro support for a fix many many times, but it does not help, so I was hoping we all can put printscreen of the temperature jumps that trigger fire hazard here, so we can see how big this issue is. I recently had a big problem with that when my customer had to travel 400 km just because of the false alarm, so it is really a big trouble sometimes.
If you have any, please post it here. If you dont know about them, check your temperature panel history and you will see them.
In my HCL i got no problems :)
I checked also smoke sensor temp.All devices are fibaro + one evegreen humiditiy.
Edited by askpc
@Bodyart ping :)
Four month ago I had the same issue with Fibaro smoke sensor (momentary increasing to ~100 deg, false fire alarm). Right after that I bought Netatmo Welcome Camera - only to be able to see what's happens in my house in real time ;D
    Today was a nice and quite day, only two "Fire hazard warnings" from the customers system. But the one goes to 120, thats record, we could boil the water there.
    Hello guys!
    @HomeSystem.sk, @reject, @Bodyart, @10der, @askpc
    If you still have our Smoke Sensor and this Some Sensor has a firmware version at least 3.2 (FGSD-002 firmware 3.2 – 3.3) or other sensor which are capable of being added in a security mode.
    Please try to re-add it in this secure mode. This should decrease the number of false reports.
    Please observer whether this improves the situation or not.
    Thanks Srodka, I always recommend this to customers. But as I mentioned, customer had temp jump on many different sensors, so it wont help all :/
    Hello @I.Srodka,
    thank you for your recommendation, but i've never experienced temperature jumps :-)
    • 4 weeks later...
    Hello finaly i got same issue with fake temp. fire alarm.
    Edited by askpc
    @askpc, and this device was added in security mode?
    It doesn't happen a lot, but when it happens it is annoying...
    On my network, about 0.01% of all reports report a temperature above 45 degrees. That's on average I'd say 2 events per months. I've had this issue for years.
    Anybody surprised how low that number is? I had an idea, but still my best guess was off by an order of magnitude... I probably thought it was higher, because it causes "a certain level of distress".
    Here's a detailed report of all my sensors, !!! marks high temperature:
    @petergebruers I didn't know you moved to Dubai :D
    So we should disable the temperature function and use only the smoke sensor in the device. May be also a solution for my problem, as
    support isn´t answering any more per email. As Im not using the HC, I can´t provide any screenshot.
