Aeotec sensor 6 USB power supply
Does any one have any experience on USB powersupplys for multible sensor 6 sensors.
Are the cheap multible port USB power packs suitable?
I'm running 2 of those on 4-port cheap (from China) like
without any problems
+4 @Bodyart
the only problem (not USB / batt issue) too much false-positive reports about high temperature...
Hi @10der,
i've never experienced those...
You have no idea how lucky you are. :D
@10derPerhaps my USB chargers are producing more stable DC (less ripple) ?
Thank you! I'll check that.
@Jamie mccrostie
I use these but not sure if they are available where you are
I am using a 5V din rail power-suppy with no problems at all~
Using DR15-5 MW by Alliexpress for around 10Dollar
Edited by samuel
    13 hours ago, 10der said:
    +4 @Bodyart
    Yes ive been testing one for a couple of weeks on a iphone charger and have recieved one “your house  is on fire”email.
    The “send high temp report”email box wont be being ticked in future
    Edited by Jamie mccrostie
    12 hours ago, 10der said:
    +4 @Bodyart
    Quite possible... Power supply quality is an issue with the Fibaro UBS (for temperature) and the Fibaro Swipe (beeps, false detection). But It also could be a Z-Wave network issue. If you ever find the time and do not mind editing your scenes... You could try to exclude the sensor and include it in "Secure" mode. From 4.141 you'll notice a "padlock" symbol on your device. If you no longer get these warnings, it was a network issue. If you still get them, it is a device or power supply issue...
    ughhhhhhh!
    so root issue (as for me) here. I have  4 MS6 and all on iphone chargers.
    AAUGH!
    @10der I only have one MS6 on batteries at the moment... So I really do not know if it is a supply issue. But before the end of the week I'll put it on USB. Probably some phone charger... I'll let you know if it starts reporting odd temperatures.
    Anyone using these too?
    RAC03-05SER
    /monthly_2017_11/41kZ-B8JygL._AC_US218_.jpg.ffea730ce4292700f79937d81bfa72de.jpg" />
    I use one of them inside the wallbox to power the USB dongle of my Qubino weather station.
    Works good so far, but probably more expensive than a simple USB Charger
    Edited by kroeatschge
    RAC03-05SER
    WoW!
    @kroeatschge Very Interesting. Thanks for sharing this. Never seen those before. Danke fürs Zeigen !
    You are welcome!
    there are different versions available. got mine at
    I have one MS6 on USB supply that came with iPhone:
    and never had any false alarms. This supply is really small and it fitted in wall box :-)
    Swipe gets juice from iPad USB supply:
    First I used old iPhone USB charger of the same shape for swipe, but after some time it started making problems with beeping and failing commands so I replaced it with iPad one and is ok ever since. Swipe is really too sensitive device and it seems that will work best with USB supplies that have good filtering and that are usually not the cheapest ones.
    On 11/8/2017 at 9:24 PM, AutoFrank said:
    @Jamie mccrostie
    @Jamie mccrostie I live in Belgium and our wall outlets are Type E (earth pin)
    I used the small one image.png.0e0478f4666cbb1888f6fe8e34fbd9d8.png but moved since 2 weeks to
    rechargeable batteries.
    using a 12V
    with no such problem. it will use the resolution available in the switch mode power supply IC
    Edited by ihakapa
    I have about 9, all on small USB type power supplies. Mostly on 5W chinese copies of iphone charger, some on 4-out chargers shared with cameras. I had a couple of false freeze/fire alarms. Interesting to hear this, will check. Thanks!
