Roland declerck 0
I am trying to connect my HC2 to my alarm installation (jablotron 100) by means of the jablotron module JA118N and the fibaro binairy sensor
based on attached documentation i found on the credex website.
It works but it is unrealiable. Status do not get updated all the time.
I first believed that there was an issue with the communication between sensor and HC2. Just to make sure i added a FGS223 in the same room
to take advantage of the mesh network. I did a network reconfiguartion for the sensor.
All seemed to work ok for a short time but then i got the same issue again: when i put the alarm on
the fibaro sensor status was not updated. NO reaction on switching jablotron alarm on or off. In jablotron the PG status is responding correctly.
When i did a "read configuration" for the module it picked up the correct status.
I would like to understand what is causing this issue and i do not believe it is a signal weakness issue.
Has somebody an idea what is wrong here (polling?), anything to test .....
12 answers to this question
